what gives on these?
pitdogg2
I've seen these on the bay for a few years now. other than parts express does polk still have the amps and why were they pulled (if that part is true)
thanks Ivan
http://cgi.ebay.com/1000W-Polk-CHERRY-Dual-10-Speakers-SUBWOOFER-LOT-4-/320606668959?pt=Speakers_Subwoofers&hash=item4aa5a5889f
thanks Ivan
Post edited by pitdogg2 on
They had a recall on the amps for these subs, and that company scooped them up. I've been wanting to score one for a while, and use it with my Behringher or Crown amp....but I don't want to pay for 4 lol.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I think they were supposed to be the match to the LSi system, but the amps were known to blow quite easily. I would say there are no parts available. You can probably get a BASH amp from Parts Express that would power them quite well as long as you could get the cutouts to match or make an adapter plate.For rig details, see my profile. Nothing here anymore...
I'd cut a piece of MDF to fit the hole, put a set of binding posts on, and then power it with my 1400w Crown XTi with the integrated x-over. It'd prolly rock the house. Hell with 2 x 700w I could wire 2 into the Crown and cause a small aftershockMain Surround -
i'd cut a piece of mdf to fit the hole, put a set of binding posts on, and then power it with my 1400w crown xti with the integrated x-over. It'd prolly rock the house. Hell with 2 x 700w i could wire 2 into the crown and cause a small aftershock
+1,000,000,000 -
Yeah, that would probably be a better solution than trying to fit something into the original cutout. The question is, whether this twin 10" sub with an external amp would be better than a single 12" SVS which would probably run the same amount after you add the cost of an amp. Dunno. Since the LSI sub never really made it out for review, its hard to say how it would sound. Maybe some of the insiders can comment?For rig details, see my profile. Nothing here anymore... -
I am in for a group buy....The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
well a few months back i contacted Polk CS and was told they were knock-offs that they never had any problem with them, and the woofers in them were cheap imitations of drivers they used. In other words complete denial and told me to steer clear of the item because of their quality
was also told by another seller at the time that a amp that PE sell is an exact match but that amp cost 500.00 and back then they(ebay seller) were asking for best offer and quite a few sold for less than 100.00 which would make it even more appelling -
I would buy an SVS sub, but I already have a Behringer and Crown XTi 1000 sitting around collecting dust (well, they're on craigslist too).
But if I had one, or two of these, I could rock the house on the cheap.Main Surround -
