Main fuse for Parasound HCA-1000 blown
jimbo1421
jimbo1421 Posts: 772
edited October 2010 in Electronics
Hello,
When my Parasound HCA-1000 power amp wouldn't turn on I checked all the fuses and sure enough the main fuse below the AC receptacle was blown. The fuse holder has, "Use only with a 250V fuse", molded into it; no amperage given. The fuse itself has "F6AL" stamped on one end. There is no information about the fuse in the user manual except to say not to replace it with a larger value.
Can anyone here say for sure what main fuse belongs here? The saleschild at Radio Shack couldn't tell from the number.
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
Post edited by jimbo1421 on
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2010
    I made an earlier suggestion of 1a/250v which was incorrect. It wouldn't do anything but blow upon power up but either way it's wrong, had loudspeakers on my mind.
    If you're talking about the fuse from the power inlet, to the main PCB, it should be 12a/250v. However, that's from peeking at my a Parasound HCA-3500, which is a larger amplifier. The draw on both is different but the design is still dual mono, basic architecture....but who knows.
    I have schematics on all the HCA series but have to dig them up. I'll let you know if you haven't already talked to Parasound by tomorrow...or whenever. PM me or email me if you need further assistance on Parasound gear.
  • jimbo1421
    edited October 2010
    Thanks, dorokusai. I will call Parasound tomorrow. Since I bought this amp used it occurred to me that the wrong fuse could have gotten in there.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • dorokusai
    edited October 2010
    No problem Jimbo, sorry for the earlier confusion...if you even read it, since I deleted the response :D
  • jimbo1421
    edited October 2010
    D'oh!
    It was printed directly above the AC inlet: 6.3A. Should it be fast or slow blow?
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • ben62670
    ben62670 Posts: 15,969
    edited October 2010
    Slow
    Ben
  • dorokusai
    edited October 2010
    jimbo1421 wrote: »
    D'oh!
    Jim
    There you go. Good work Magoo.
  • jimbo1421
    edited October 2010
    All is well now. Parasound confirmed the fuse as a 6.3A/250V slow blow. The counterman at Walker Electronic Supply pointed out that the F in F6AL stands for fast blow. That is probably why it blew. A week ago the amp would not turn on except after I jiggled the power cord at the inlet. I must have been jiggling the fuse a bit to to get it to close.
    The sound is better now. I had noticed a bit of occasional scratchiness which is gone now. I think the fuse was opening a bit intermittently.
    Thanks for your help.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • ben62670
    edited October 2010
    Glad you got it up and running :)
    Ben
