RTi70 Tweeter Problems
I recently replaced the tweeters on my RTi70. One speaker has come back to life but the other one doesn't come close to its original sounds, it still sounds weak and low.
Could someone please help me out.
Post edited by puissant on
did you check and make sure the spades are on tight on the tweeter?
Check the Binding posts 'jumpers', maybe one came loose.
Swap speakers, L > R to see if it is coming from your amp.
If neither of those work, swap then tweeter between speaker, and see if the issue follows the tweeter or stays with the speaker.
If you get to the end of that list, come back..
Good luck ..Sorry
