Redoing vinyl cabinets
NeilGabriel
NeilGabriel Posts: 1,487
edited December 2010 in Vintage Speakers
I think there is a link to some of you who have redone cabs on Monitors.....is this even possible on the vinyl covered ones?
I was thinking of faux painting....or whatever that is called....
ng
Post edited by NeilGabriel on
  • fatpiggy
    fatpiggy Posts: 205
    edited October 2010
    Hi Niel,
    Im in the process of rebuilding a pair of RT 12's with vinyl cabinets.I thought about re spraying the cabinets but found on closer inspection that the paint was actually black ash vinyl.
    I have done a bit of hunting around and have found Parts Express sell the same black ash vinyl.They also sell the cherry and other wood grain sheets.If you want to remove the old vinyl you can use a heat gun or hair drier and it will lift ok.Then just give the sides a clean with some paint thinners to remove the old glue.The rest is just slow peel stick and smooth with a rag to remove the bubbles.Finish off the edges with a razor blade and sharpy if you miss a few edges.To re vinyl would cost about $20 plus your time
    The other option I was originally thinking about doing was to take the cabinets down to the spray painter and get them to 2 pak the cabinets piano black for a super gloss finish.Would cost around $100
    I spoke to a cabinet maker yesterday that does kitchens and he told me he could veener lamanate the cabinets easy using the same type of veneer they use on kitchen bench tops and cupboards.The types of finishes are endless.Would cost around $100
    Regards
    Fat Piggy
  • kcoc321
    kcoc321 Posts: 1,788
    edited October 2010
    Neil,
    Geoff has done several pairs, mostly he has done Mon 5's. He did a sweet looking piano black pair, that I saw, which were gorgeous and a pair with maple that I only saw pics of, but they look nice as well.
    I thin he has threads post on here about them.
  • NeilGabriel
    edited October 2010
    kcoc321 wrote: »
    Neil,
    I think he has threads post on here about them.
    thanks both....will look for thread....small successes help my self image in a big way!
    http://www.fauxlikeapro.com/decorative-paint-samples.shtml
    click on link and then on wood
    ...what I need to find out is if this can be done on the fiber board (that is the cab, right?)....gotta friend who is great at this technique....
    F1nut Posts: 50,761
    edited October 2010
    Way too cheap for either option.
  • messiah
    messiah Posts: 1,790
    edited October 2010
    I recall a thread a while back where Trey veneered his rt55i's. You might want to ask him if that's the way you want to go.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • Coleman
    Coleman Posts: 17
    Interesting thread. I want to pick up a used 5JR+ through craigslist to use a center channel and it's in cherry. My original set are black ash. There are some spray paints out there that chemically bond to plastic. Has anyone actually successfully spraypainted a vinyl cabinet to change the color? I really don't want to go through the effort of stripping and cutting vinyl sheets.
  • DON73
    DON73 Posts: 516
    I have a pair of monitor 7s that are very ugly wood grained vinyl and I'm thinking about spray painting them. Rust Oleum makes a "vinyl" spray paint that is supposed to contain vinyl and they claim it will adhere to any vinyl surface. They even claim it can be used on dashboards and seats. I don't know if the vinyl on speakers is the same chemical composition but I'm going to buy a can today and try it. Black. If I do I'' post the results.
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • brgman
    brgman Posts: 2,859
    Purple spray paint seems to be a favorite for SDA's around here.:biggrin:
    I’M OFFENDED!!!!
