rear surrounds
mike701
hey all you polk guys, I want new rear surrounds for my system, I have the rti70 for fronts and the csi40 for the center I want some rears to go with that and I tried the fxi50's but they don't come in white which I want for cosmetics. these will be going into the corners of a 20x25 room with a slightly vaulted cieling
Post edited by mike701 on
Welcome to the forum, this discussion has been brought up several times in the near past, if you do a search you will find all you need to know, Look at polks lineup and speakers they have to offer in your RTi line, I have the same speakers you have. If you don't like the fxi50's, then the only other comparable speaker is the Rti38, or the smaller rti28.. I have the 38's and they sound fine, I mean its hard because the rears aren't ultilized all that much and when they are it's for short periods thus making it hard to tell what is good and what is great!! 28 or 38's would work great! No other real options, in this lineupMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
