2.3 upgrade
Audioquest
Audioquest Posts: 104
edited October 2010 in Vintage Speakers
What is the most significant audible upgrade to a seemingly perfectly functioning pair of 2.3's?
HT: Polk SDA SRS 2.3 main fronts, Klipsch RC-25 center channel, Polk RTi-150 rears, M&K V1B sub, Denon AVR-5800, Samsung 52" LCD, Sony BDP-S550
2 Channel: Carver ALS Platinum, Audio Research LS-2B preamp, Counterpoint SA-100 amplifier, Integra CD player, Denon SL7D tt, TC750 phono pre, Nikko tuner
Post edited by Audioquest on
  • gdb
    gdb Posts: 6,012
    edited October 2010
    $10,000.00 amplifier ??:eek::D
  • zarrdoss
    zarrdoss Posts: 2,562
    edited October 2010
    new tweeters RDO 194
  • george daniel
    george daniel Posts: 12,096
    edited October 2010
    hmmmmm, caps n' resistors were the first thing for me,,ymmv.
  • zarrdoss
    edited October 2010
    Not as easy as new tweeters, but just as valuable IMO
  • george daniel
    edited October 2010
    zarrdoss wrote: »
    yep,,I just have a thing for crossovers.;)
  • zarrdoss
    edited October 2010
    me too now that I know there isn't really anything to rebuilding them.
  • shadowofnight
    shadowofnight Posts: 2,735
    edited October 2010
    http://www.polkaudio.com/forums/showpost.php?p=1443925&postcount=2833
    Best upgrade to a set of 2.3's is to get a second pair for a hundred bucks :eek: I sure hope a forum member gets these...
    The first rule of Fight Club is you don't talk about Fight Club
  • zarrdoss
    edited October 2010
    Holly S**t! somebody better run!
  • cnoat
    cnoat Posts: 315
    edited October 2010
    I just talked to him and was gonna make a road trip.Just pulled away.ARRRG
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • Audioquest
    edited October 2010
    Wow, that is a crazy good deal if they are in good working order
    That's what I was thinking. Maybe my questions should have been what is the FIRST upgrade to be done.
    ...thanks all!
  • Schurkey
    Schurkey Posts: 2,104
    edited October 2010
    Audioquest wrote: »
    Agreed. Caps for sure; enough folks think replacing the resistors is important and so I did...although I'm really not convinced that the resistors degrade over time. I AM convinced that Polk was "overly generous" with the tolerance range of the parts used in the crossovers; so I suppose upgrading to tighter-tolerance resistors is likely a good thing.
    If the crossover is degraded, NOTHING else is going to make the speakers sound right.
    Toolfan66 Posts: 17,337
    edited October 2010
    Well since crossovers and tweeters are covered. Those would be my One and Two upgrades, the next steps for me would be Spikes (getting them off the floor) Dynamat the steal baskets, and install rings.
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • chosenalready
    chosenalready Posts: 17
    edited October 2010
    Audioquest wrote: »
    My recommendation on the most significant audible upgrade if you have to pick one would be tweeter replacement. I have replaced the caps and resistors in my 2.3 and 2b's (no TL mod). The audible difference of before and after was small to me. Later I TL modded the 2b's and changed the tweeters out for some SL3000's and this conversion was astonishing. It was very noticeable how the speakers sound had improved. Long story short; Go with the RDO-194 tweeters first. I think you will be surprised. Just my 2 cents. ;)
  • Audioquest
    edited October 2010
    Thanks for all the replies. I think I'll likely recap first to make sure everything is in spec, (did that to the Carver Platinums) and then do the tweeter upgrade next. Is the TL mod worth it and what does it consist of?
  • zarrdoss
    edited October 2010
    I don't think it can be done on the reg 2.3's not very easily anyway.
    edited October 2010
    Don't worry bout the tl mod, you would be better off finding a set of tl's.
    You will be happy with what your doing with these.
    SVS SB16 X2
  • Audioquest
    edited October 2010
    What exactly is the difference of the TL model? Those are the ones that don't have the disc on the woofers right?
  • ben62670
    ben62670 Posts: 15,969
    edited October 2010
    They are totally different. The drivers and XO's are totally different.
    Ben
  • Audioquest
    edited October 2010
    ben62670 wrote: »
    Ok, good enough, thanks. One last question. I haven't taken the drivers out yet, but do you know if the speaker cabinet top and bottom caps come off or are they integral with the rest of the construction? I'd like to make the replacements of gloss piano black finish as the rest of my equipment, stand, and TV is black and I think that would really make them look a lot more up to date, not that the wood looks bad.
  • chandler9a
    chandler9a Posts: 878
    edited October 2010
    I may be wrong but I think you will see that you can remove those top and bottom caps once you open them up.
  • george daniel
    edited October 2010
    Improve your sonic abilities/qualities first,,crossover upgrade and tweeters,,then tackle the cosmetics,,just my humble opinion.
