Computer self help
opus
opus Posts: 1,252
edited October 2010 in The Clubhouse
Guys and Gals,
I think I need to cleanup my computer a little bit (nothing major) and am looking to do it myself. A couple of years ago I was using a site that walked you thru the process in a very simple step by step way. It allowed you to download all the free tools to do the proccess. I can't seem to find that site again or another place like it. I thought it was reached going thru CNET but I am not sure.
Anybody know of a site like this. It needs to be dumbed down pretty far for me to be able to do it;)
Any help? Thanks...................kevin
The Flea rig
Hitachi 50VG825 LCD
Rotel RSP 1066 (pre) :)-flea market
B&K St-202 (mains)-flea market
Carver M 200t (x2) (center and surrounds)-flea market
Blu-Ray..PS3 (dvd player)
Polk RTA-11t-flea market
LsiC, Fxi30's
Dual SVS PC-Utra's (1 port blocked) thanks MikeC78
Behringer Feedback Destroyer
-flea market
AudioAlchemy DDE v1.0 DAC-flea market
Cambridge Audio Azur 640 CDP-flea market
Signal Cable and Kimber Kable
Post edited by opus on
  • opus
    opus Posts: 1,252
    edited October 2010
    I think my computer is set up to defrag on a schedule. Is this different than what you are talking about?
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • opus
    opus Posts: 1,252
    edited October 2010
    doing the malware thing as we speak
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
    txcoastal1 Posts: 13,358
    edited October 2010
    Lasareth is correct with the malwarebytes dont get sucked up by other software cleaners, there are a couple other things you can do especially if you have some really pesky trojans is once malwarebytes is installed and updated run the the program in "safeboot" or "safe mode" this is where the system only runs on its essecentials and can be entered by
    1)windows start key
    2)type into the search or run window (depending on OS)---"msconfig" then enter
    3)system config file will open tab over till you see safeboot and check the box the restart the system ( you will exit back to "normal" the same way you got here after running malwarebytes)
    4) run malwarebytes when this is complete repeat step3 and click normal and reboot
    for damaged registries you can also run CC Cleaner another safe free software
    http://ccleaner.softwarereviewer.info/?gclid=CIyz68LW66QCFQSt7Qod_UNu2A
  • opus
    opus Posts: 1,252
    edited October 2010
    alright so I ran the malware and found 4 low level adware thingys.
    I running vista so we have been defragging on schedule.
    My main problem is slowness. It takes forever to open up things like quickbooks and such
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • ryanjoachim
    ryanjoachim Posts: 2,046
    edited October 2010
    Yeah, Malwarebytes and CCleaner. That's all you really need, besides actually going through and uninstalling old programs.
    As for boot times, there's a fairly simple process for that. Go to Start>Run. Type in "msconfig" (minus the quotes).
    Now, a warning - don't mess around in here. It can mess your install up pretty well if you go to the wrong spot.
    Go to the Startup tab. Start going through that list (looking at the first column first, then the 2nd) and uncheck anything that doesn't need to be running. For the most part, nothing in this list will cause any problems with Vista itself, but other programs might be affected by proxy.
    This list shows every program that starts up when you boot windows. 95% of these programs don't need to be started automatically. By unchecking as many as you can, you will notice an increase in speed during the boot-up process.
    One last thing before you try the msconfig option - Hit ctr-alt-del, and look at where it shows how much memory you have vs how much you are currently using. If that amount is over 60%, chances are you're dipping into your virtual memory every time you try to open a program, which would slow you down dramatically.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • opus
    opus Posts: 1,252
    edited October 2010
    So when I downloaded and ran the cc cleaner it wants me to buy " active pc optimizer" to fix stuff is that what I need to do?
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited October 2010
    be careful with things like ccleaner. If i recall, that tries to "clean" the registry too. Rarely, but sometimes you will experience problems after performing such a task... sometimes pretty big ones.
  • opus
    opus Posts: 1,252
    edited October 2010
    thnaks for the help everyone
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • renowilliams
    renowilliams Posts: 920
    edited October 2010
    One other thing...you might want to invest in Windows 7. It is a far superior operating system than vista. You will truly feel like you've upgraded.
    "They're always talking about my drinking, but never mention my thirst" Oscar Wilde
    Pre-Amp: Anthem AVM 20
    Amp: Carver TFM-35
    Amp: Rotel RB-870BX
    Fronts : SDA 1B w/ RDO-194s
    T.V.:Plasma TC-P54G25
    Bluray: Oppo BDP-93
    Speaker Cables: MIT Terminater
    Interconnect Cables:DH Labs Silver Sonic BL-1isonic
  • messiah
    messiah Posts: 1,790
    edited October 2010
    The defrag in windows sucks. I use perfect disc and it makes a big difference. You also should use a registry cleaner.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • opus
    opus Posts: 1,252
    edited October 2010
    Lasareath wrote: »
    How's the PC running today?
    Better, thanks.
    Still seems sluggish at times when opening items like Quicken or switching browsers.
    k
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • wz2p7j
    wz2p7j Posts: 840
    edited October 2010
    +1000
    I'm a little more radical, I say uncheck all of 'em. Re-start the computer and see if the performance is better. It usually will be. Check to see if there's something that normally starts up on it's own that you miss. Usually there won't be. But if so, go back to the startup menu and check stuff until the computer returns to your expected behavior.
    I've fixed so many computers by the above procedure. Getting people over the "uncheck all of 'em" hump is the hardest. You're not going to break anything and can always go back in and check all of 'em. :p:p
    Chris
  • opus
    opus Posts: 1,252
    edited October 2010
    Lasareath wrote: »
    what are the specs of the PC?
    If McLoki is reading this I know he is laughing because he knows that I have no idea what the specs are. :o
    I'll see if I can look them up
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
  • devani
    devani Posts: 1,497
    edited October 2010
    add more memory if the computer is slow....
    as others suggested I have Malware and MSE (microsoft security essential) both free running everyweek.
    memory, best bang for the buck
    Video: LG 55LN5100/Samsung LNT4065F
    Receiver: HK AVR445
    Source: OPPO BDP-93
    HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
    2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83
    edited October 2010
    FYI- Programs like quickbooks are alway slow to open. I have a real mean PC and the only way quickbooks opens quickly is segregating your OS drive. I use a Patriot Torx for my OS with Raid5 for my data. Some programs including PDF's are just that way do the structure and encryption decoding....so you may not have issues... only issues maybe RAM and processor
  • opus
    opus Posts: 1,252
    edited October 2010
    Alright guys thanks for the help. I think I have it narrowed down to a memory problem.
    Appreciate the help
    kevin
    The Flea rig
    Hitachi 50VG825 LCD
    LsiC, Fxi30's
    -flea market
