I-tunes question
ben62670
ben62670 Posts: 15,969
edited October 2010 in Electronics
Can other players like the zune play I-pod music from I-tunes?
Ben
Ben
Post edited by ben62670 on
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    edited October 2010
    I suppose you mean music that you paid to download through itunes? they should all be MP3's and probably stored in My Music/itunes on a PC. In any event, the answer should be yes. If they are in apple lossless format, they might have to be converted.
  • bigaudiofanatic
    bigaudiofanatic Posts: 4,415
    edited October 2010
    All depends on the format. Bought music I believe is still encoded unless you buy the "plus" music you rip from a cd again depends on the format. I know my format apple lossless which is uncompressed would probably not be readable to a zune or other mp3 device. I know my droid has a app that allows me to use apple lossless music on it.
    HT setup
    Panasonic 50" TH-50PZ80U
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    MIT Exp 3 Speaker Wire
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    63 inch Samsung PN63C800YF
    Polk Surroundbar 3000
    Samsung BD-C7900
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    Wouldn't the device need specific apple software to sync properly with iTunes?
  • bigaudiofanatic
    edited October 2010
    Only ipods can sync with itunes from what I know.
    HT setup
    Denon DBP-1610
    Monster HTS 1650
    Carver A400X :cool:
    Kef 104/2
    URC MX-780 Remote
    Sonos Play 1
    Living Room
    Samsung BD-C7900
  • FTGV
    FTGV Posts: 3,650
    edited October 2010
    That would be my guess as only iPods have the onboad Apple software .
