Jesse another wood question...
steveinaz
steveinaz Posts: 19,538
edited October 2010 in The Clubhouse
Help...
I want to refinish our rustic dining room table. It's just stained, with no sealing finish on it.
I'd like to sand it lightly, re-stain and use some sort of finish coat. This is where my question comes in; Bev doesn't want a shiny finish, but we want good protection--what would be the best product to get this result?
Thanks alot in advance...
Post edited by steveinaz on
  • steveinaz
    edited October 2010
    Here's a pic of the table if it helps: (I'm guessing it's pine?)
    F1nut Posts: 50,873
    edited October 2010
    PM sent.
  • halo71
    halo71 Posts: 4,608
    edited October 2010
    awww come now, why all secret squirrel with the PM's? Some of us others may wanna hear about this too. :)
    --Gary--
  • steveinaz
    edited October 2010
    Thanks Jesse, you da man.
  • steveinaz
    edited October 2010
    Table came out real nice, thanks again Jesse. For those wondering, the steps were:
    -Mineral spirits to remove contaminates, wax, ect
    -Light sanding w/220 grit to remove scratches, water glass stains, etc
    -Wipe down to remove sanding dust
    -Stained with minwax golden oak using a brush, let set for 8 minutes before wiping (let set overnight)
    -3 coats of wipe-on minwax poly in satin finish. 3hrs between coats.
    The satin worked perfectly, giving the finish a rubbed look, without being overly shiney. It now matches the finish on the buffet.
    I'll post an "after" pic tonight.
  • edbert
    edbert Posts: 1,041
    edited October 2010
    Good info! I have some furniture similar to this that I was wondering how I should finish it. I at least now have the direction I may need to go in. Thanks to you both for sharing!
    I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius. :D
    Pioneer VSX-816
    Monitor 40's - fronts, bi-amped
    Monitor 30's - surrounds
    CS1 - center
    PSW10 - I'll let you guess
    Blue Jeans Cable - speaker cable
    Daewoo 27 incher - one step up from a console
    Sony Progressive scan DVD
    XBOX
    SOPA since 2008
    Here's my stuff.
