Have a HTPC and now confused....
disneyjoe7
So have a HTPC working an OTA antenna in my family room, and is working fine. What are my options either seeing what's recorded on or just watching tv in a bedroom?
Steve
Steve
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
What OS and software are you running? I would think content-sharing over a network is standard fare, but it might have to be enabled first.
If you are using Windows Media Center then you can just use an extender one of many companies that produce one (Netgear/D-Link/Linksys etc...)
Running WMC Windows 7 home, if extender could this see everything on WMC like Hulu?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »Running WMC Windows 7 home, if extender could this see everything on WMC like Hulu?
Probably not. Hulu doesn't publish it's stream through MCE. You would need something like Boxee. This space is still terribly fragmented. -
Will I did something that does Hulu in my MCE, not perfect as I need a mouse at times but then ok with remote. If that way could it work?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Will I did something that does Hulu in my MCE, not perfect as I need a mouse at times but then ok with remote. If that way could it work?
Currently anything that allows Hulu Playback in MCE is simply a hack around. The issue is that Hulu, so far, is not going to provide an API (a programmers toolbox) to natively and cleanly integrate Hulu with MCE. -
So I thinking about this device http://www.amazon.com/Cisco-Linksys-Media-Center-Extender-DVD/dp/B000XQONSG/ref=sr_1_3?ie=UTF8&qid=1287759781&sr=8-3 is this good?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »So I thinking about this device http://www.amazon.com/Cisco-Linksys-Media-Center-Extender-DVD/dp/B000XQONSG/ref=sr_1_3?ie=UTF8&qid=1287759781&sr=8-3 is this good?
The reviews aren't too bad for that unit. I can't speak to it's functionality since I have never tried it.
Your best source for information is thegreenbutton.com -
Thanks Jinjuku I'll check it out.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »Thanks Jinjuku I'll check it out.
YW, let me know what you decide to go with.
