Onkyo preamp
brgman
brgman Posts: 2,859
edited October 2010 in Vintage Speakers
Does anyone know how to get the speakers set to off or whatever they need to be set at to get it to recognize an external amp?
Thanks:o
I’M OFFENDED!!!!
Post edited by brgman on
    EndersShadow Posts: 17,690
    edited October 2010
    You shouldnt have to set any of that stuff. It should just recognize it once you hook up the pre-outs to your amp.
    What model Onkyo?
  • brgman
    brgman Posts: 2,859
    edited October 2010
    TX-NR808.
    I figured it would as well but after running the interconnects and moving the speak wires i got nuthin'
    wtf?
    i saw in an old thread someone "turned off" his speakers.It was an older Onkyo though.
    i set them to NONE and that's just what i got.None.
    I’M OFFENDED!!!!
  • phocion
    phocion Posts: 157
    edited October 2010
    "If you want to use a more powerful power amplifier and use the AV receiver as a preamp, connect it to the PRE OUT jacks, and connect all speakers and the subwoofer to the power amplifier. If you have a powered subwoofer, connect it to this AV receiver’s SUBWOOFER PRE OUT jack. You can connect the powered subwoofer with two SUBWOOFER PRE OUT jacks respectively. The same signal is output from each jack. Note
    *1 Specify “None” for the channel that you don’t want to output." TX-NR808 Manual pp. 16
    So, set them to something other than "none".
    The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche
  • brgman
    brgman Posts: 2,859
    edited October 2010
    I'll try that again.I didn't have them set to "none" on the first try.Let's see what happens.
    I’M OFFENDED!!!!
  • brgman
    brgman Posts: 2,859
    edited October 2010
    Nothing
    i will go get new i/c's tomorrow but not sure why these monsters do not work.(if it's them)
    I’M OFFENDED!!!!
  • CCNJ
    CCNJ Posts: 384
    edited October 2010
    Before buying new ICs make sure you connected everything correctly. First make sure that you connected the ICs to the PRE-OUT jacks in the back of your receiver. Then the other end of the ICs get connected to your external amp. Then connect the speaker wire from your external amp to your speakers.
    Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
    Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4
  • Earthy
    Earthy Posts: 488
    edited October 2010
    I have that very same Onkyo TX-NR808 and use it as a pre-amp to my Adcom 555II. I couldn't find any setting to turn the main channel amp off. It works like a charm. It must recognize that there is no load.
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • brgman
    brgman Posts: 2,859
    edited October 2010
    Ok,the amp had a standby mode in between on and off.thats where i had it set.duh.
    Now i just need to eliminate the hum and i'll be great.
    Thanks for all of the input!
    I’M OFFENDED!!!!
  • kefranklin
    kefranklin Posts: 141
    edited October 2010
    Hey brgmn I am using an old Onkyo tx-4500 as a pre for an Audiosource Amp Three. When I plugged it in I was getting a bad hum. After reading some forums, I saw suggestions to plug in the amp with a three to two prong adapter. This eliminated the noise and it has worked fine since.
  • brgman
    brgman Posts: 2,859
    edited October 2010
    kefranklin-IT WORKED!!!
    YOU ARE THE MAN!THANKS FOR THE HELP!!!!!
    I’M OFFENDED!!!!
  • Earthy
    Earthy Posts: 488
    edited October 2010
    I don't have any issues with hum. Both of mine are plugged into the same wall outlet. I don't remember if they were grounded but I think they both are. That 808 is one big AVR. Mine won't fit on my shelving. Good thing it's only temporary.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • nguyendot
    nguyendot Posts: 3,594
    edited October 2010
    You can also just ground the two chassis together.
    Main Surround -
  • kefranklin
    edited October 2010
    I am glad everything worked out. That hum was extremely upsetting when I first powered up.
  • Schurkey
    Schurkey Posts: 2,122
    edited October 2010
    kefranklin wrote: »
    Fixing ground loop properly requires more than a cheater-plug.
    Cheater-plugs are illegal in some states.
    Defeating the built-in grounding for your components is potentially dangerous.
  • kefranklin
    edited October 2010
    I am sorry if I oversimplified the solution. That is as far as I have gotten with it since my house is not grounded anyway.
