Elite vs Intergra
  • dpowell
    dpowell Posts: 3,081
    edited October 2010
    Couldn't tell you on the Onkyo but I sure like my Elite.
  • WilliamM2
    WilliamM2 Posts: 4,806
    edited October 2010
    Just as a addendum to my post, the repair shop just called to tell me my Integra is fixed, it needed 8 capacitors changed on the HDMI board, which is the exact same fix they use for SRx06 Onkyo models..
    Integra used to mean something, now they are just re-badged Onkyo's with a different face plate, so I'm not surprised it used the same parts/fix. I've had a 9.8 and an 885 open side by side, not a single difference inside at all. The Onkyo's toroidal even had a label on top that said "Custom designed for Integra". I guess they normally put a sticker over it that says "Onkyo".
  • dorokusai
    dorokusai Posts: 25,576
    edited October 2010
    Agreed. I have the TX-NR5008 and aside from aesthetics, it's the same internally to the Integra DTR series. It used to be exclusive but that was years ago. I do prefer the aesthetics of the Integra lineup over the stock Onkyo. Any high-end shop that sells Integra is simply embarrassed to carry Onkyo....audio snobbery will always exist.
