Jesse, wood care question...
steveinaz
steveinaz Posts: 19,538
edited October 2010 in The Clubhouse
My Carbon 7's are real wood veneer (ribbon mahoghany) I think they've just been "hand rubbed" with oil as there doesn't appear to be varnish or any other clear coating on them.
What's the best way to maintain this kind of finish?
Post edited by steveinaz on
    treitz3 Posts: 19,297
    edited October 2010
    Steve, that's the exact finish I have on my Tylers. Mine are too new to have thought of this question before but I'd be interested in diving into Jesse's brain on this subject. Thanks.
    tonyb Posts: 33,030
    edited October 2010
    I have speaks in the same ribbon mahoghany, I just use lemon oil by hand but if Jess has a better product, I would like to know as well.
    F1nut Posts: 50,873
    edited October 2010
    steveinaz wrote: »
    If you mean dusting, just wipe off the dust with a slightly damp soft cotton cloth and call it a day.
    Otherwise, if they really have an oil finish, you will need to reapply oil to them every once in awhile. Like every few years or when they start to look very dull and dry. I'd recommend using a product like Watco Danish oil. If Watco is used, follow the rag disposal instructions to the letter.
    Lemon oil is nothing more than mineral oil with lemon scent added, zero lemon oil. Personally, I would never put mineral oil on anything I own, although there are worse choices.
    There are finishes that may appear to be an oil rubbed finish, but are not. Therefore, I would recommend contacting the manufacturer to find out exactly what they used. For example, I could apply a coat or two of thinned out varnish and it will end up looking exactly like an oil rubbed finish, but with better protection, which will not dry out.
    Tom, are you sure they don't have a clear coat on them? Didn't I see a spray booth in those pics you showed me of the factory?
  • halo71
    halo71 Posts: 4,608
    edited October 2010
    Jesse, where does boiled linseed oil fall into use here...if its an alternative.
    --Gary--
    F1nut Posts: 50,873
    edited October 2010
    Unless you have a genuine antique piece of furniture that was done in linseed oil, forget about it as it is actually a terrible choice.
  • ShinAce
    ShinAce Posts: 1,194
    edited October 2010
    halo71 wrote: »
    Boiled linseed oil is linseed oil for the impatient. It 'dries' faster, but still doesn't offer the best possible protection.
    Watco danish oil is a classic.
    Personally, I'm still having fun with wax.
  • Polkitup2
    Polkitup2 Posts: 1,623
    edited October 2010
    treitz3 wrote: »
    You may want to double check with Ty as the finish on my Linbrook Monitors is actually a light satin lacquer finish - I talked with Ty about the finish as I had some light scuffs I wanted to fix.
    edited October 2010
    Jesse, he does have a spray booth.....or at least he did in the old factory. That said, I don't know whether or not he sprayed any kind of finish on the veneer or not. It may have just been for the bases, subs or another line I am not familiar with. I'll get in touch with him when time allows and get back with you.
    Thanks Polkitup2, they do have a shine but it is very subtle. Being heavy into paints and not wood finishing, it looks more like a velvet flat sheen -vs- a satin finish but that doesn't mean a damned thing. Two separate animals, I would imagine. I just wish I had contacted him before he put the velcro tabs on for the grills. On my last pair, I tried everything in my book and the finish was still not quite right when I tried to remove them. He says, once they are on....there on.
    I need to contact him anyway due to wanting to do some custom work to the rig to match the speakers so maybe I can knock out two birds with one stone.
  • Face
    Face Posts: 14,340
    edited October 2010
    I've been using this on my furniture and veneered speakers: http://www.rockler.com/product.cfm?page=17424
    F1nut Posts: 50,873
    edited October 2010
    Face wrote: »
    That is the best wax money can buy. Highly recommended!
    Tom, I'm sure the clear coat is lacquer.
  • Ricardo
    Ricardo Posts: 10,636
    edited October 2010
    My Ribbon Mahogany Linbrooks had some clear coat; urethane or something like that.
    SOPA
  • steveinaz
    edited October 2010
    Thank you or the help Jesse.--Thanks Face.
