SDA-SRS 2 (Bi-Amp version) w/198's
Hamatym
Hamatym Posts: 269
edited March 2011 in Vintage Speakers
OK, I think I know the answer already.....BUT Inspiredsports got me thinking. Can the Bi-Amp version of the SDA-SRS 2 ever be converted to handle RDO-198's? I just got these and added RDO-194"s...all stock XO's which sound much better than I expected. I think the answer is no 198's and live with the RDO-194's.....but had to ask as I like the 198's more.
Any input is appreciated, and if there is an answer I would love help!
Dan
Post edited by Hamatym on
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2010
    It isn't the tweeters that cause the issue. It is whether or not you can tie the grounds together. for the SDA effect.
  • gdb
    gdb Posts: 6,012
    edited October 2010
    Joe08867 wrote: »
    HUH ?:confused:
  • gdb
    gdb Posts: 6,012
    edited October 2010
    AFAIK, the differences between the 194 & 198 has never been clearly explained on here, or what precludes them from being interchangeable. Will the crossover burst into flames while the Earth opens up to swallow you,:eek: or....will it just not sound as good as it would with the correct driver/s installed ?
  • gdb
    gdb Posts: 6,012
    edited October 2010
    Referring to an explanation that a non-tech person (me) can understand.
  • Schurkey
    Schurkey Posts: 2,104
    edited October 2010
    Joe08867 wrote: »
    I suppose that's a concern--but--it's a completely DIFFERENT concern that the original poster is dealing with.
    Most folks wouldn't refer to the SRS2 as "non-bi-ampable" or "bi-ampable". They'd say "blade/blade" or "pin/blade" SRS2. But, yes, the pin/blade SRS2 does have the jacks on the back for biamping.
    I suppose if the low-frequency amps are common-ground you'd be OK; and if not, you'd need an AI-1 or similar substitute. By my reading of the schematic, there's no SDA cross-coupling in the HF crossover, so it wouldn't matter if the HF amps were common-ground or not AS LONG AS THE JUMPER WIRES CONNECTING THE BINDING POSTS ARE REMOVED.
    gdb wrote: »
    Different frequency response, different impedance.
    In some other designs, for example the blade/blade SRS 2/SDA 1B, the crossover has a 4.4uf capacitor to filter out the low frequencies from the tweeter circuit. Replacing the 4.4uf capacitor with a 5.8uf capacitor is about all that's needed to "convert" to the 198s from the 2000/194. But there's no guarantee that that modification will work with the later pin/blade SRS2/SDA 1C style crossover. Apparently, no-one has tried it; or worked the math to prove/disprove that changing that capacitor makes for a successful upgrade to the 198s.
    If I owned the 1C or later SRS2, I'd yank the 4.4 for a 5.8, swap tweeters for the 198s and see what happens...but I don't, so I can't. I did do that with my 1Bs, but I was just copycatting a mod already proven to work.
    Seems to me that if both the early and late SRS 2s use a 4.4 cap in the HF crossover; and if the early one can be swapped for a 5.8 to tune the crossover for the upgraded tweeter...my intuition says that same deal applies to the later SRS2/1C crossover, too.
    Some folks feel better about "engineering" than they do about "intuition". And that's ok, too.
  • george daniel
    george daniel Posts: 12,096
    edited October 2010
    Why not just upgrade the crossovers
  • Hamatym
    Hamatym Posts: 269
    edited October 2010
    Thanks for a lot of the info guy's! Here's the thing, I always here the SDA 1C's / SRS 2 P/B CAN NOT be modified to take the RDO-198's....but yet there seems to be a way that others think it can.
    I have modified 2.3TL's and SDA-2B TL'd, so I would love to upgrade the SRS-2's and keep them in the same 198 "Family". I don't mind being a test mulem but my skills upgrading XO's is not good. I relied on Ben to handle these issues. Ok, well no biggie...I was more curious than anything. The RDO-194's are certainly a HUGE improvement, so I am not complaining!
    Thanks all!
  • Joe08867
    edited October 2010
    I'll be honest and tell you I really read this thread poorly.
    Now for my take on the real question. I can't see why you wouldn't be able to do the swap. Like Schurkey said:
    I would surmise that subbing a 5.8uf cap in place of the 4.4uf would do it. Looking at the schematics it doesn't look like an issue. It's a shame they never made these in a TL form.
  • Hamatym
    Hamatym Posts: 269
    edited October 2010
    Well, since I had Ben do my 2.3TL XO upgrade....I gave him a shout and He said he would give a full XO upgrade and involve this (potential) TL mod as well!
    If this works, it should work for SDA-1C's as well right? Please anyone else chime in on this topic before I cast them off to Ben. Much appreciated!
  • gdb
    gdb Posts: 6,012
    edited October 2010
    I hope that it works out for your p/bl.SRS2s. Does the 198 sound that much different/better than the 194? Are you going "top shelf" with your caps & resistors when you have Ben upgrade the XOs ? I'm waiting to do mine until I can afford the Mills-Sonicap parts + the cost of 4 tweeters. Now, it looks like I might end up with a choice of which tweeter to install. Can't wait to hear how it goes !:D
  • Hamatym
    Hamatym Posts: 269
    edited October 2010
    Ah the age old question as to which RDO is better...ha ha Both are awesome!
    To get in my head, here are my personal thoughts:
    - If you want to save a couple bucks and plan to keep the XO stock, go RDO-194's along with the other simply mod's....then call it a day for a great sound!
    - Now if one can spend the extra $$ for a full XO upgrade, I found the RDO-198's react better than the 194's, and the clarity goes to a whole other level.
    Just my thoughts, I also like keeping all the tweeter's alike incase I ever have to mix in speakers years from now. I am on a 198 mission...ha ha
  • Schurkey
    edited March 2011
    Hamatym wrote: »
    Any update on the success or failure of the 198 upgrade to a 1C or SRS2 with pin/blade?
  • Hamatym
    Hamatym Posts: 269
    edited March 2011
    Well I went a different route and they are now in dcmartinpc hands for this upgrade. I think he is selling off some speakers before hand, but the question is still valid. I decided to change my inventory to models that take the SL3000 stock...then upgrade the XO's and 198's to be safe:)
