What SDAs Are These?
villock
villock Posts: 72
edited October 2010 in Vintage Speakers
Looking to possibly buy these. He is asking 150.00. I have been looking since August for some SDAs and these are the only ones to come up for sale in my area. Anyways I think that they are 2As. Can anyone confirm, is 150.00 a good price and are these worth getting? By the way there is no cable with these. Thanks.
SDA SRS 2.3tls; RDO 198's, Dynamatted, Armaflexed, Gimpod Boards, Crossovers by quadzilla: Clarity ESA 630V, Mills Resistors, Track Audio Spikes, Musky's Curly Maple Caps
CSi5, FXi5, Rythmik D15SE sub, Pro-Ject Xpression III/Ortofon MC-3 Turbo. Pro-Ject Speed Box. Pro-Ject Tube Box II
Post edited by villock on
    nooshinjohn Posts: 25,926
    edited October 2010
    2a's is my guess...
  • geppy1
    geppy1 Posts: 3,076
    edited October 2010
  • Rev. Hayes
    Rev. Hayes Posts: 475
    edited October 2010
    Looks like you have a blade/blade interconnect socket so I'd say 90% sure they are 2A's.
    They look just like the 2A's I bought last week for $200 (w/ cable and original boxes) so $150 is not a bad price. Just be sure to check all the drivers before you hand over the cash.
    Sounds good to me...
  • ben62670
    ben62670 Posts: 15,969
    edited October 2010
    That is a steal.
    Ben
  • gdb
    gdb Posts: 6,012
    edited October 2010
    Talk them down to $125.00 to help cover the cost of an I/C cable.;)
  • villock
    villock Posts: 72
    edited October 2010
    ben62670 wrote: »
    That is a steal.
    Thanks. Even without the cable? Also where can I get one?
  • gdb
    gdb Posts: 6,012
    edited October 2010
    Polk still sells the blade/blade ones.
  • villock
    villock Posts: 72
    edited October 2010
    gdb wrote: »
    Does anyone know how much this would cost?
    Also how important is placemant for these? I am thinking about putting these where my RTi12s currently are and both of these are against walls. Also how will these compare to my 12s. I listen to 50/50 HT and 2 channel. Thanks.
  • Bobsama
    Bobsama Posts: 526
    edited October 2010
    For all SDA models, placement is extremely important. First thing is to never toe-in the speakers, and second is that the best image will be produced when an equal distance from all walls. They should generally be 6-12" away from the back wall (YMMV: the closer to the wall, the better the bass response, but too close and they become very boomy). SDA's should be no closer than 6' apart and you should sit between (x=distance apart) x and 2x feet away, centered between the two. Obviously, the closer they are, the smaller the sweet-spot. If you can separate them sufficiently, you can fit a loveseat or sofa into their sweet-spot and have very good imaging for all ears in that area. The closer you are to them, the wider the soundstage, so play around with placement.
    Do grab an SDA cable from Polk: these speakers are OK without it, but shine with the cable.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
