what model speakers I have
craigxlh1
Hi can you tell me what model speakers I have
there 28 inches high x 16 x11 inches they have a 10 inch woofers and 2 6 1/2 mids and 1 inch tweeters meaure(4 1/2 x 3 inch) SN 10-73013 AND 10-73012
thanks
craig
thanks
craig
Post edited by craigxlh1 on
You have Monitor 10's.....Depending on the tweeter will dicatate which version you have.
Also, the 10" woofer isn't really a "woofer". It's actually a passive radiator. It doesn't have a magnet on the back like a normal driver would, and it's completely passive(not powered by an amp). To put it simply, the back pressure of the mid-woofers is what drives the passive radiator. It's sort of like a really complex bass port.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
