Enclosure for SR124
![nstillmatic](https://w3.vanillicon.com/31eb2aad2ee62fa61e09102f59c19275_100.png)
nstillmatic
I'm looking for an enclosure for an SR124, I know the best route is to build one yourself, but I don't know that I have the time or ability to do it myself. I've looked around for websites that build custom boxes but I couldn't really find anything.
Would something like this be sufficient?
http://www.sonicelectronix.com/item_24427_Absolute+MSHF12.html
Here is the recommended dimensions from Polk:
http://www.polkaudio.com/caraudio/subbox/subbox_plan.php?id=96&mesurements=standard
Post edited by nstillmatic on
How many watts are you sending to the sub? The sub is rated for 700watts RMS. If you are powering it with close to RMS watts, then 1.2-1.25cuft would be fine. If you're powering it with say 3-400 watts you can look at going with a slightly smaller enclosure.
I plan on sending the full RMS to the sub, do the dimensions or anything of that sort matter as far as SQ goes?
Would this work?
http://www.sonicelectronix.com/item_951_Single+12-+Sealed+MDF+Enclosure+-12SQTC-.html -
If im not mistaken 1.20-1.25 is air space needed AFTER sub is installed. Since sub itself takes up .14 sg ft u'll need your box to be in 1.34 - 1.39 area (1.2+0.14 or 1.25+0.14)2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
