Any Ideas or pictures of homemade center speaker stands for tv's
myke
So I bought the CSi A6 and man it's BIG, ENORMOUS!! My problem is should I build a center speaker cover for the TV to sit on and stay on top of the entertainment center or should I put the center over the TV on a shelf (mostly hidden...quasi floating). Both will look somewhat ackward but I have to do something till we move and I end up mounting the TV and all my problems are solved. All advise is welcome.
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
Myke check this thread out and go down to post #11 thats where Im at except I need more space for amps. I dont want to rebuild and start over so I guess I might build on top of what I already have. Check it out.
Matt
http://www.polkaudio.com/forums/showthread.php?t=107929Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears... -
TOOLFORLIFEFAN wrote: »
looks like you did a good job on that stand.mole' -
Thanks for the comments everyone, I ended up buying these real low profile L braces/brackets.
________
kinda look like that but cooler, made of steel, 11'"x8"x1", I sanded the powder coat and spray painted it with an oilbased paint that matches my walls, eventhough its behind the TV anyways, you cant even see the brackets since the center is right over the TV floating about 1/4'' over it at most. I didnt want to raise my TV above eye level when sitting. Drilled them into the studs so they can handle the CSi A6 weight (30lbs). I'll try to throw some pics up soon if nyone wants to see them, I know pics always help me.Bonus Room:
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
old sony receiver (replacing soon) -
my pic got messed up, imagine the /'s pushed over to the right like a brace for the upside L shape. BTW, they were only like $6 each and the srcews were $1.88 for 3 and I used 6, Spray paint was $4ish. Pretty cheap overallBonus Room:
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
