Blown Speakers-Help?!
taliercio
Need some help - bought parents RM6500 speakers,including RM2300 satellites 2 years ago. Upon visiting recently, noticed first that Denon receiver was shutting down as if there was an overload, then upon closer inspection, released that person who rewired speakers had input and output reversed for the Front speakers. Did a sound check, and there was nothing, switched the rear speakers up Front, and they worked, so it's definitely the speaker.
Are the speakers beyond repair, and if so, what is a recommended replacement for the RM2300
thanks for the help
thanks for the help
Post edited by taliercio on
last i checked, circuitcity.com sells the 2300 satellites.
joe
HI:
Call Polk and see what they offer.
Gary -
Hello,
I believe you sent an email on this subject, correct? If so, I responded, giving instructions on sending the satellites in for service. Let me know if you have any additional questions.
Regards, Ken Swauger -
thanks again for you help
John
