Watts!
Alright so i was told tht on a sub the watts didnt matter tht a 500w wit proper cabniet and woofer it kan deliver high output is it true u dnt need more watts to feel/hear more bass?! and another question around how much wuld it take to build ur own sub say a 12/15" sub tht hits 16hz ?!any ppl tht build ther own nd if so how it go?!
__________________
__________________
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3
There are a wide variety of DIY subs for different applications.
Depending what your level of wood working is, budget, and well several other things will determine the right build for you (if any).
I'm a little cloudy on the forum but I'm sure you can google DIY subwoofer and find several forums/threads/projects posted online.
I built one myself last year, and several members on here have built some as well.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
with subs its all about moving air. I built a 18" sealed sub with only a minuscule 240 watts rms it sounds fantastic and gets low and loud. I might build a bigger ported version in the future.
