Which speakers go better witht the CSiA6 center, RTiA5 or 7's?
myke
myke Posts: 138
edited October 2010 in Speakers
The title pretty much ask the question, I went with the center first b/c I thought it was the most important but man, that thing is enormous!! What works best with my center, the RTi A5's or A7's?? Or should I return it for the A4 center and pair up the RTiA5/7's? All opinions are welcome. I have a descent size room, 22'x15' and it an open space to the kitchen, not to mention where moving soon and all homes we looking at are similiar or a little bigger.
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
Post edited by myke on
  • PrazVT
    PrazVT Posts: 1,607
    edited October 2010
    They are all voice / timbre matched, so in that sense you'll have a good experience with either the A5 or A7. I listened to the CSi A4 at Frys, and though it sounds great, the low end (dialog esp.) is a little lacking. I ended up taking the plunge and going with the CSi A6. It is definitely a noticeable step up from the CSi A4. And my apt living room is similarly sized (perhaps narrower by a few feet). In the long run, the A6 is worth it.
    Once you do the Pioneer speaker setup, it'll blend nicely. As for the towers, you'll probably get a bit more low end with the A7s since they have woofers in addition to the midrange. Otherwise, I would go listen to them both and see which one YOU like. Both will blend perfectly w/ your system.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • myke
    myke Posts: 138
    edited October 2010
    Thanks PrazVT, I unfortunatly cant go listen to them anymore with the only store around here closing and therefore i'm reliant on reading opinions and a good return policy :), I aapreciate the info and will try to keep the A6 but man it is BIG, and thats what my wife said AS SOON as she walked in the house! :) I guess i am worried more about missing the mids from a A5/A4 mix vs a A7/A6 since I have a descent sub to pick up the lows, dont want too much bass (if thats even possible :))
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2010
    myke wrote: »
    When your wife walked in and said 'that thing is BIG' did you reply with 'that's what she said' :cool:
    And no, you can never have too much quality bass.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • myke
    myke Posts: 138
    edited October 2010
    :)haha, ... No but I did say something similiar....just dont want to repeat it on the forum. And your right, too much bass???whats wrong with me....novice!! Again, the mids were my main concern, don't want them to be drowned out by the bass.
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • Gulfstrings
    Gulfstrings Posts: 313
    edited October 2010
    All the work's been done for us.
    http://www.polkaudio.com/homeaudio/rtia/systems.php
    Good luck.
    Marantz AV7005
    Marantz MM7055
    Onkyo DX-755 CdP
    Oppo BDP-93
    Technics SL-1301/Shure M97xE
    Polk RTi A7s
    Polk CSi A6
    Polk FXi A6s
    Velodyne VDR10-BV
    Panamax M5100-PM
    Antec VERIS A/V Cooler x 2
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2010
    With a decent sub the a5's sounds fantastic. You can't go wrong with either speaker.
  • myke
    myke Posts: 138
    edited October 2010
    oh yeah, i've studied the page, but that could just be a good rule of thumb or general assumption and practical exp means something else. Thanks though. It comes down to is it worth the size, will it work better with the A7's, or are the A5/A4 or A7/A4 combo better than the A7/A6? I know i'm beating it to death but need to be sure before I drop some cash since i'm down to the wire and second guessing myself. Thanks everyone!
    Bonus Room:
    RTi A7's / CSi A6
    DSW PRO 600 sub
    Samsung BD-C5500
    Living Room:
    Samsung 58" PLasma
  • Ericw2431
    Ericw2431 Posts: 228
    edited October 2010
    Alright so i was told tht on a sub the watts didnt matter tht a 500w wit proper cabniet and woofer it kan deliver high output is it true u dnt need more watts to feel/hear more bass?! and another question around how much wuld it take to build ur own sub say a 12/15" sub tht hits 16hz ?!any ppl tht build ther own nd if so how it go?!
    Room Theater:
    Fronts:RTIA3
    center; CSIA6
    AVR: Onkyo 709
    panasonic 55"plasma
    Ps3 slim 250gb
    surrounds.Fxia6
    Sub...svs pc13 ULTRA
    Amp:Emotiva xpa3
  • Upstatemax
    Upstatemax Posts: 2,798
    edited October 2010
    I pulled the trigger on my A7's and I was "on the wire"...
    I'm GLAD I did! They are a great speaker, I don't see them letting you down.
  • gfong
    gfong Posts: 1,079
    edited October 2010
    RTi A7's have a few posts lately and with good reason. Fantastic speaker for home theater use. Matched with the center you have it will sound really nice.
    I have the same center that you purchased and also have the RTi A7's up front. (see sig)
    The A6 is really crisp and clear. Don't take the CSi A6 back, it rocks for a center and you probably will not out grow it even if you upgrade your fronts sometime, which you probably will not have to! :)
    Good luck with your system.
    I have not heard the A5's but can atest to the great sound the A7's put out for home theater use. You will not be disapointed.
