Which PS Audio power conditioner you own?
deluxman
deluxman Posts: 24
edited October 2010 in Electronics
Folks,
I am thinking of getting a PS Audio power conditioner. At first I was going to get the AV5000 but later on I read that the Duet seems to have the same filtering capability. My current power conditioner is Panamax M5100. Do you guys think by using PS Audio power conditioner will give me some improvement or should I just stick with my current Panamax? I am just trying to justify if spending a few extra bucks on the PS Audio will give me some improvement. Also does anyone ever own the two PS Audio I mentioned? Is the AV5000 better than Duet or is the Duet good enough??
Please share your experience or comments before I spend my money.
Thanks.
Post edited by deluxman on
  • playback
    playback Posts: 101
    edited October 2010
    deluxman wrote: »
    Folks,
    Thanks.
    Hi, I use the Quintet, but if all you need are just 4- outlets the Duet is a great choice and only gets better with a good after market Powercord.My quintet is dove tailed from a soloist premier with oustanding results over the Monster 2500mk2 it replaced, both audio and video and not by a small margin. hope this helps.:D
  • MADGSF
    MADGSF Posts: 603
    edited October 2010
    I also have the Quintet and am very happy with it. I changed many things at the same time, including the TV, so I can't say what improvement it brought. I do like the ability to use a 12V switch to turn outlets on, the ability to use a better main power cable and it's robust construction. I don't feel the need to move up to a better conditioner at this time.
    AVR: Elite VSX-21TXH
    Amplifier: B&K 7250 Series ii
    Misc: Velodyne SMS-1
    Mains: RTi-10
    Center: CSi-5
    Rear: Boston DSi460
    Sub: SVS PC-Ultra
    TV: Panasonic TC-P58V10
    DVD: Panasonic DMP-BD60K
  • deluxman
    deluxman Posts: 24
    edited October 2010
    Here are the response from Ryan at PS Audio regarding the difference between the Duet and the AV5000:
    "The Duet is good, no bones about it. But the 5000 is even better.
    The Duet begins filtering in the 35kHz level and the 5000 begins at about half of at. Or in other words the 5000 begins filtering the audible frequencies. It also carries over to higher frequencies.
    I personally have a 9000 that uses the same filtration boards as the 5000, as well as a Duet. Having compared the two I can tell you there is a pretty significant sonic improvement when stepping to the 5000.
    Besides the primary filtration benefit you also have the 5 Isozones which will allow you to isolated you component from each other, thus further reducing noise interaction."
    What do you guys think? Should I go with the AV5000 or just the Duet or maybe the Quintet?
  • Ern Dog
    Ern Dog Posts: 2,237
    edited October 2010
    I always find it beneficial to address the weakest link in the whole audio chain including the room. Taking this approach, your money might be better spent somewhere else or not.
    For example if you are focused on upgrading the conditioner, but are using a cheap dvd player as your source then it is wasted money.
    What other gear are you using?
  • deluxman
    deluxman Posts: 24
    edited October 2010
    I am using all Arcam gears for CD player and receiver. Will go separate in the short future. Subwoofer is Velodyne, Shunyata Power Cables and Kimber Kable for interconnects, digital coax and speaker cable.
  • TrashyTrucker
    TrashyTrucker Posts: 225
    edited October 2010
    Deluxman,
    I still use the max 5100. If you decide to take it out of line, tell me where you are at and set it outside by your door!
    Matt :D
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
  • jayman_1975
    jayman_1975 Posts: 672
    edited October 2010
    I use the quintet on my stuff.
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • Ern Dog
    edited October 2010
    I have a Quintet and have mixed results with it. When I first got it, I thought it helped, but then retested it later and found that it took away some of the dynamics, so took it out.
    I'll have to do more critical listening to tell if it helps my system sound better or not.
  • deluxman
    deluxman Posts: 24
    edited October 2010
    Ern Dog wrote: »
    Hi Erndog!
    I had the duet and the AV5000 and of course I did compare to my current Panamax M5100. The result is night and day. The sound through the Panamax, is bright and fatiguing. This is not just my imagination as I asked my wife to sit down as well and listen and without telling her, she could distinguish the sound is totally different. Then I plugged thru the Duet...it also sound better than the Panamax but not as clear as the AV5000. To me the Duet has a tad less filtration than the AV5000. It is not as dark as the AV5000 for the background. AV5000 produces better separation. The highs are just more laid back and non-fatiguing is the word I would say. I could not believe it myself that power conditioner makes such a difference. Of course in this test, all the power cords are upgraded ones. I used Shunyata Taipa Alpha for the receiver, Harmonic Pro AC 11 for the power conditioner and Shunyata Diamondback Platinum for the CD Player.
    If anyone else, think or find the conclusion otherwise regarding AV5000, please share your experience here.......
