Amplifier Power Consumption Problem
Serendipity
Serendipity Posts: 6,975
edited October 2010 in The Clubhouse
As some of you may know, I run the PA at my church and it basically consists of pro cabinets driven by an Adcom GFA-535 amplifier. The unit has clip LED's which rarely light up even when driving low-impedance loads.
I also have a Radio Shack MPA-250 with output power level LED's and noticed something interesting:
On songs # 1, 3, and 4 the power output can be low while achieving a high dB output. On songs # 2, 5, and 6 the amplifier can easily be driven into clipping without producing much output.
1. http://www.youtube.com/watch?v=2CJvO6WaoKc
2. http://www.youtube.com/watch?v=oEauWw9ZGrA&ob=av2e
3. http://www.youtube.com/watch?v=_4FpUhtfbBY
4. http://www.youtube.com/watch?v=do5-9C6LaH4
5. http://www.youtube.com/watch?v=f7VoXvRr86A
6. http://www.youtube.com/watch?v=rJYcmq__nDM
What exactly is the reason for this? The second song (pon de replay) is especially hard on ANY amplifier, and it concerns me that both the Adcom and RS MPA-250 are showing high power output without much audible output.
What gives?
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Post edited by Serendipity on
  • Serendipity
    edited October 2010
    The Adcom GFA-535 and Radio Shack MPA-250 are both rated down to 4-ohm operation. Load is a single pair of Ramsa PA cabinets, which run at 8 ohms, and should not present a problem to the Adcom. At home I have the MPA-250 hooked up to a pair of Polks as outdoor speakers, and a second pair of small HTiB speakers on the "B" speaker outputs.
    What's strange is the Hayley Williams song can have TONS of output with only 3 bars lit on the Radio Shack amplifier, but others (like Rihanna) will totally make the amp go to 0 pretty quickly.
    Does listening to the songs on your setup produce similar results?
  • messiah
    messiah Posts: 1,790
    edited October 2010
    I think God doesn't like you playing Rihanna in church lol :rolleyes:
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • Serendipity
    edited October 2010
    Never said it was. The Adcom, mixer, and pre are all mine - donated from many years ago - so I do get to use them once in a while. When you spent many summers mowing lawns to be able to afford the gear, then you should be able to borrow it back on occasion.
