AI-1 interface
TrashyTrucker
looking for the original, not diy. But might reconsider if it will work in my application.
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears...
Rotel RCD 1520 cdp
biamped to:
Post edited by TrashyTrucker on
Ok what else can I use? can I buy another interconnect cable and make my own? I have the pin/blade configuration now.Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
biamped to:
...SDA's are just like candy for your ears... -
How much do these typically sell for?
Two Channel Setup:
Speakers: Wharfedale Opus 2-3
Integrated Amp: Krell S-300i
DAC: Arcam irDac
Source: iMac
Remote Control: iPad Mini
3.2 Home Theater Setup:
Fronts: Klipsch RP-160M
Center: Klipsch RP-160M
Subwoofer: SVS PB12NSD (X 2)
AVR: Yamaha Aventage RX-A2030
Blu Ray: Sony BDP-S790
TV Source: DirecTV Genie -
I have an original one. When I got it the previous owner cut the wires from the box and reconnected them to one another to make a regular interconnect cable. I reconnected the cables to the box and solder them but on one side of the box I could not get the cable thru. So I taped the box closed. Naturally the cable is behind the speakers and you would not be able to see it so it didn't bother me. I functions properly. If you are interested I would sell it for 80.00 dollars shippped. I mint condition I have seen them sold on ebay for hundreds. Let me know.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
I've paid $200 for an original one with an original box.
Then 2 years later I sold it for $200
Thank you, sir.
Two Channel Setup:
DAC: Arcam irDac
Source: iMac
Bluecoment,
Is that pin/blade connections?
MattIntegra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
biamped to:
It is pin/blade. They came with a set of 1.2tl's I own.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
