ADCOM 555 on SDA-1C
Valentine
Valentine Posts: 46
edited October 2010 in Vintage Speakers
I was wondering if anyone had dual 555 on a pair of sda-1c. I just wanted to what the raw power of 700 plus what does for the sda-1c. I currently have a Parasound A21 on them, but was wondering about maybe doing raw power. Any help would be greatful
thank you Mitchell
Post edited by Valentine on
    heiney9 Posts: 25,217
    edited October 2010
    You can't run mono block or bridged mono amps with SDA's. There is an AI-1 interconnect that will allow you to run true mono amps with certain model SDA's, but it's not recommended to run bridged mono amps on SDA's because of impedance issues.
    Only certain SDA's can use the AI-1 cable. Some 1C's can use it (AI-1 interconnect) , but not all.
    It's about quality power not quantity power, so my answer to your question is NO.
  • Earthy
    Earthy Posts: 488
    edited October 2010
    I hear that bridging the 555's and other amps tend to bring the quality of the sound down some as well. I am personally looking for an A21 so if you decide to sell yours, let me know.
    Polk Audio SDA SRS 2.3TL
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    Polk LSiM 707, 706c, 703, 705
    Polk Blackstone TL3 for height
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    Logitech Harmony Elite
    PC LSiM 703
    Spare LSIM 702 and 706c
    Home Theater #2
    Polk Audio LS70, CS350LS, LSF/X, S4
    Onkyo TX-NR808
  • Dawgfish
    Dawgfish Posts: 2,554
    edited October 2010
    I didn't try bridging my 555, but I found my GFA-555 to be a little too much on the bright side with my SDA-1Cs and I have the RD0-194 tweets on mine. I used the 555 with an Anthem tube pre with Mullard tubes and tube buffers with my CD(Opera Audio CD120 Balanced) and SACD (Denon 2900) and it still sounded bright to my taste. YMMV, but IMHO there are a lot better matches ampwise out there for SDA-1Cs. I would definitely stick with your Parasound over dual bridged GFA-555s.
  • george daniel
    george daniel Posts: 12,096
    edited October 2010
    first hand experience-- 1 adcom 555 with 1c's=kinda bright,,bridged adcom 555's with 1C's and the AI-1 non common ground interface cable==NASTY BAD
  • phocion
    phocion Posts: 157
    edited October 2010
    I am currently looking at an ADCOM 555 mkII in LA, any better than the original in terms of brightness?
    The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche
  • Earthy
    Earthy Posts: 488
    edited October 2010
    I just got a 555II hooked up to my SDA SRS 2.3TA's and think it sounds great. My room is not the best acoustically. Lots of reflective surfaces. I listen to a lot of classic rock, and honestly until I hear a "non bright" amp, think it sounds great.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • phocion
    phocion Posts: 157
    edited October 2010
    Great, thanks for the feedback!
    edited October 2010
    I've had a few original Adcom's and they were never bright on SDA's. You have to use a decent pre-amp with them in my experience.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited October 2010
    i've got my industrial gfa555 hooked to 2 20 y/o refoamed Infinitys sm112s.I can get up to about 5-6 on my pre before neigbors start their complaing. The Adcom is fine my wish i
    s a pair of cornwall-3s or hereseys.
    2-channel
    Adcom gfa55
    Infinity sm112s
    Deon1910ci cdp
    Dual 1219 turntable
  • Hawkeye
    Hawkeye Posts: 1,313
    edited October 2010
    I have my 501's hooked up to the 4 Ohm tap giving 1K of watts with 90 amps going to the SRS2. These speakers will rock!! I'm using the AI-1 until my Dreadnaught is complete. The case is at the powdercoating joint. I had a bit sybilance until I changed out the tweets. To me a very smooth speaker with no brightness to mention.
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
  • phocion
    phocion Posts: 157
    edited October 2010
    Well, that is enough positive reviews for me to drop $250 on a 555II.
    Incidentally, most of the reviews I have read indicate that the original 555 was bright, but that the mark II was a lot more neutral. Hopefully I will find out for myself by this weekend :)
    edited October 2010
    phocion wrote: »
    I preferred the original series amps. But for $250 either one is a good deal.
    Enjoy
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited October 2010
    Sounds like a nice price on a nice amp for your SDA;s. Drop us some pics here when you get it.
  • phocion
    phocion Posts: 157
    edited October 2010
    It is from a Loyola Marymount film and TV program in LA, and they have 2@$250, so if any other LA polkies want the other one I will PM the contact info.
