Help to clean my shoes.
PerfectCreature
Okay, scouted the interwebs, nothing short of don't do this do that crap.
So, asking for anyone who has ever really looked at their once bright white shoes and saw they were as black as the pair of work shoes sitting next to them.
Anyway, I have a pair of cloth white shoes. They are really dirty from mud and dirt.
Wondering the best way to bring them back to white; I don't need them all the way white, but at least whiter than they are now.
Any tricks or whatever to clean a cloth shoe? I have done leathery like ones with tooth brush and tooth paste and stuff like that, but am not sure how that would work with cloth shoes?
Thanks.
Thanks.
Receiver
Harman Kardon HK 3490
Speakers
Polk Audio Monitor 50s
Subwoofer
Klipsch KSW-100
Cables
AudioQuest Rocket 33s 10ft
AudioQuest Optilink1 2m
AudioQuest Alpha-Snake 25ft Interconnect
AudioQuest HDMI-1 2m
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Post edited by PerfectCreature on
you serious? Washing machine, detergent, bleach. Air dry.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
The sites I read up on said that would shrink the shoes or something like that.
Our work just went to all solid color shoes, and those shoes are the most comfortable shoes I have, they are just really dirty.
I thought about washing them in the machine....but is is kind of cold.
Could I just stick them in the dryer with like cold air to them to not shrink?Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
Samsung Smart TV 40" 1080p 3D -
Don't do wash machines. Mix some detergent, tad bit of bleach with warm water. Using a brush ( scud brush preferrably new or very clean)dip it into your cleaning agent and scrub hard. This should remove any and all dirt while also cleaning the soles making them new-like again. Remove any cleaning agent from the shoe with a clean towel and allow them to air dry. I have been using this method since I was a Marine. If you have white strings place them in the water and allow them to soak. Once your shoes are done, remove the strings from the water, wash them in your hands in a back and forth motion as if you were washing your hands. Rinse under warm water and let dry. You can toss them in the dryer afterward also.Shoot the jumper.....................BALLIN.............!!!!!
Okay, yeah I think i will do that.
So the dryer won't shrink them or melt the foam or what have you?
Thanks.
It is getting cold up here in Maine, so air drying would take days.. haha.Receiver
Speakers
Subwoofer
Klipsch KSW-100
Cables
Alienware X51 R2
PS4
You have some of the weirdest post's..:)
You might need this as well..
http://www.youtube.com/watch?v=2fQ-OXJ_xOM -
Try a white eraser The good kind, if not try a magic eraser (Mr clean). So far, it has worked for me to remove any dark scuffs from my white runners
I've taken some white slip ons from vanns and thrown them in the washer and never had problems. otherwise when I had to do stunts and had comps we always had to have the cleanest shoes possible, those we would clean with hand and buff out any scrapes and crap on them as we were also check over by the staff and the meets to make sure we didn't bring crap onto the floor.
A washer on the gentle cycle will not hurt white cloth shoes....a dryer with heat will shrink them a bit in my experiences.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
Trash can.
Wash them with detergent in the washing machine and leave them in front of your fridge to dry. I've always done this and never had any shrinkage problems.2007 Club Polk Football Pool Champ
"It's like a koala bear crapped a rainbow in my brain!" -
Try Oxy-Clean with a soft bristle brush, it works well for most stains and general grime.
+1^^^^
If you were married, you wouldn't have to bother yourself with these issues.Sal Palooza
mrbigbluelight wrote: »If you were married, you wouldn't have to bother yourself with these issues.
LMAO....brilliant!Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
This kid is a riot!!If you can't hear a difference, don't waste your money.
I thought he was married? Unless the black belt, ex-marine guy finally stole her away. Maybe she's cleaning his shoes?
Chris -
Dude, a lot of us FOG's grew up wearing Converse All Stars, and when they got too dirty for our mom's to tolerate, they went into the washing machine.My equipment sig felt inadequate and deleted itself.
Dude, wouldn't it had been easier to just google a fix for your problem ?
Airing all these little woes of yours isn't doing yourself any favors. Be it as it may, I would have never bought white cloth shoes to truck around the dirt in to begin with. Just sayin' is all. Toss 'em.HT SYSTEM-
lsi 9's -
Unbelievable, dude!
I'd use the 'significant other' to do the dirty deed :D lolTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
Ajax mixed with warm water and lightly scrub with a soft brush. Gonna have to get them soaking wet. Rinse VERY well and let air dry. This has always worked for me.
Now that its getting cold out I can see your next post.....how do I get the stuck jacket out of the zipper......
No way man, it's going to be "I lost a mitten, does anyone know how to find a lost mitten?""They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
Wear clear rubbers over them! . . . NO NOT THAT KIND YOU PREVERTS!
hearingimpared wrote: »Wear clear rubbers over them! . . . NO NOT THAT KIND YOU PREVERTS!
Oh ...... I should have read your entire post before proceeding ...........
.......... good thing they weren't really clean ............ I guess ...............
Well, at least my shoes are white ! :eek:Sal Palooza -
Buy some new freakin' shoes....
mrbigbluelight wrote: »Oh ...... I should have read your entire post before proceeding ...........
White from what!?! WAAAAAAAAAAAAAAAA!!!:eek: EEEEEWWWWWW!!!!
