Question about connections
mike929
Hello,
I am new to the forum and have been reading alot of information. However I still have some questions. So please take it easy on me.
I recently starting acquiring my home theater setup. So far I have a Pioneer SC-25 , Monitor 60,40 and CS2. I still need a sub and wiring/connections (looking at getting from Monoprice ).
The speakers have 4 posts on the back connected with a metal bar ( from upper posts to lower posts) as i'm sure you are aware. Do i only need to connect into one pair of posts?
Also would I be able to bi-wire these to my SC-25? If so would it be worth it?
Monitor 40
Monitor 60
Pioneer Elite SC-25
Thanks in advance
Monitor 40
Monitor 60
Pioneer Elite SC-25
Thanks in advance
Leave the jumper in place, connect to either. as for your second question...i would say no. Welcome to CP.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
+1 and IMO you would get no audilble difference with bi-wiringParasound Avc-1800
Mains-Rti 12 -Parasound 1500a
Center-Csi5-Parasound 1000a
Rears-Rti 8-Parasound 750a
Sub SVS Ultra Tv 12
Diamondback and King Cobra IC's
AQ T4 SC -
keep on the jumper for now and just conect the ends to one set of posts.
When people do upgrads etc they may change out the metal jumpers for a set of speaker wire to match the speaker wire they are using in general to improve SQ ect. This is not something you need to do right away.
Regarding the 2nd thing, I would not bi wire. However if you want to you can try. Remember bi wiring is different than bi amping, so if you are confused let us know so we can explain the difference.
Also when bi wiring make sure you remove the metal jumpers as otherwise its not good.
Welcome to CP! -
thanks for the quick replies
I'll leave it as is for now.
And from my understanding bi-amping ( to me equals this bi - means 2, so 2 amps ) which I do not have.........yet -
If you are interested in the differences in bi-wiring and bi-amping, you can read these:
http://en.wikipedia.org/wiki/Bi-wiring
http://en.wikipedia.org/wiki/Bi-amping
