upgrading center channel
I am looking to upgrade my center channel that came with my Polk 6700 series. Any suggestions? I would like it to be seamless with the front satellites of the Polk 6700 series. Has anyone tried a different center with this speaker set-up like the CSi30 or CSi40?
Post edited by Tim on
can't say I have tried either center with the 6700 but I do have the CS400i, older sibling to the CSi40 and I have to say it was one of the best additions to my setup. I was lucky enough to get all of my speakers out of the same series and it makes a world of difference.
I would suggest calling Polk and asking them what you asked here. See what they say would be a good match for the setup you have, also ask if an older series would match and if so which one. Then do some shopping and see what you can find.
Circuit City and other dealers should start to discount thier current Polk speakers soon as the NEW line is due out late summer / fall. You might be able to get a good deal on a "older" model that is still new in a box.
Best of luckFront
Polk RT800i (BI-wired)
Rear
Polk RT600i
Center
Polk CS400i (BI-wired)
Sub
SVS 25-31PCi (22Hz tuning port)... it's SubHuman
Receiver
YAMAHA RX-V1400
TV
Mitsubishi WT-46807 HDTV
HD receiver
T i V o HR10-250 -
