Anyone tried Walker SST on driver and tweeter terminals???
geppy1
Has anyone tried putting Walker SST on driver or tweeter terminals? I know it works on speaker terminals .
Post edited by geppy1 on
Yes, worked well for me.
Remember that the Walker SST effect is cumulative. I recommend carefully applying it on the crossover connections first, then listen to the results. 1) If the outcome is to your liking, don't remove the application and move on to the drivers; or 2) if you don't care for the results of that application, carefully remove the application using DeOxit, then move on to the drivers. Use the same process for the driver application, and finally for the tweeters. -
On the tweeters, did you think it brightened them or smoothed them?? keith
