fxi a6 vs fxi a4
mr300
mr300 Posts: 21
edited September 2010 in Speakers
I recently purchased the Rti a5 towers and the csi a6 center. Should I get the fxi a4 or 6's for my rear surrounds ordoes it really not matter?
Post edited by mr300 on
  • leroyjr1
    leroyjr1 Posts: 8,785
    Both will work just fine with your setup.
  • domflane
    domflane Posts: 653
    If you can fit them, the A6's are obviously better speakers. I have the same setup and its great for HT.
    RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
    Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
  • mr300
    mr300 Posts: 21
    Are the fxi's better or Rti a1's as surrounds? I'm just trying to get the best for the money.
  • domflane
    domflane Posts: 653
    I used 5 1/4" bookshelves for rears for a couple years, and now after getting FXiA6's I can't believe how much better they are. The dispersion across the rear is seamless now, I have a hard time hearing the location of the speakers. For HT, I strongly recommend the FXi's. If 5 channel music is your thing, then the Bookshelves might be better for you.
  • mr300
    mr300 Posts: 21
    This will be more for theater use so I guess I'' go for the fsi a6. Do you know if there is a big sound difference between 5.1 and 7.1?
  • domflane
    domflane Posts: 653
    That depends on the size of your room and available speaker placement. For small rooms, you won't hear much of a difference. If you have the space and the coin, give it a try. 7 is > 5 after all.
