how do you reinstall your audio drivers?
MeredithSS
Post edited by MeredithSS on
Uh, a website.......
Go to your Soundcard companies website, and search for Drivers there. Search for your soundcards driver, install it. That is how I would do it. If you use soundblaster or w/e, go to soundblasters website. Etc.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
What operating system are you using? If you can find the device manager this should tell you if the drivers are functioning. If there is a red X on the soundcard you may need to reinstall them using the latest version from the manufactures website."The only way to get rid of a temptation is to yield to it."
