Plans for DIY subs ??
I have been pondering a diy sub for a couple years now. Budget I want to spend is about $ 700. Have space for a ported sub. Dont know why I want to instead of just buying one but it is something I would just like to do. But I find plans but dont really know the actually outcome of them. I am looking for plans of someone that has actually made one and knows what it turned out like. I realize this is pretty vague but if you have built something and it rocks please reply...
Klipsch RF7-II
Klipsch RC64-II
Klipsch RC62-II
Onkyo TX-SR805
Dish 722 dvr
Sony BDPS370 Blue Ray
Samsung 52b750 LCD Tv
Panasonic DVD Recorder
Post edited by schutz2106 on
  • megasat16
    megasat16 Posts: 3,521
    edited September 2010
    Well, building a good subs require a few tools and a software to design the enclosure based on the driver T/S parameters. I hope you are building a sub for fun and enjoyment coz the DIY subs aren't a lot cheaper than the out of the box ready made subs.
    For $700, there are lots of good choices from Elemental Design, SVS, Epik, HU, Polk and many more.
    If you want to go for a reasonably easy and good DIY sub plans, check out parts express for Dayton Audio DIY subs. I think they have design plans there too.
    You can also buy Rythmik Audio Direct Servo sub kit for around $700 and you can download the plans from Rythmik website.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • megasat16
    Also, check out DIY Cable site at diycable.com for their Malestrom subwoofer drivers. You can find lots of DIY plans for the DIY Cable Subs in many audio forums.
  • FTGV
    FTGV Posts: 3,650
    megasat16 wrote: »
    +1 nice subs ,IIRC I think GR Research makes an equivelent.
  • ken brydson
    ken brydson Posts: 9,005
    For that kind of coin you could get a nice pre-built sub. If you're set on DIY, here's a great driver to get you started...
    http://www.polkaudio.com/forums/showthread.php?t=107130
  • jinjuku
    jinjuku Posts: 1,523
    Try this Infinity Kappa build from Audioholics.com
    You can use the Kappa 120.9 (~$140), Sheet of cabinet grade plywood ($40), and amp like the Peavey IPR 1600, and an external eq/x-over like the Elemental Design Audio eQ.2. $100. So ~$600
    It's been measured, corner loaded, with 120dB at 20Hz at ~2 meters. If I ever go ported subs this is the one (make that two of them) that I would build. Later on you could build a second Kappa go stereo with out purchasing any more electronics.
    Check out Haoleb's build thread of the Kappa Sub.
    Also the recommendations for DIYCABLE.COM are solid. Check out the Shiva-X2 and Tempest-X2. Tons of different cabinet designs (ported and sealed) good application notes.
    Both the Infinity and the Shiva/Temptest are low distortion, very linear, high power handling designs.
  • jinjuku
    $700 DIY will most likely net him a sub that would be north of $1300 commercially.
  • edoggrc51
    edoggrc51 Posts: 584
    jinjuku wrote: »
    +1, at least $1300 LOL!
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Quad DIY LMS Ultra subs (powered by dual IPR-7500 amps)
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
    2ch: Emotiva Stealth 8's, Airport Express
  • Valentine
    Valentine Posts: 46
    I've actually built the last two of my home subs, First one was an actual car woofer i had laying around, i built an enclosure, reinforced it with internal bracing and purchased a plate amp to mount on to it. Then proceed to have it single stage painted black. The second one i order all my parts from partsexpress.com. I order a Dayton 18, bash 500 plate amp, wood veener, and a set of ports and spikes.I used 1" mdf for the front side and 3/4" mdf for the remainder of enclosure. Then put in some 1" wood polls (from any local hardware store) Spent around 550 for all of the parts. Could of bought a Velodyne DLS-4000r for about the same price. But it was a fun project, and turned out very well i think. We now call my home CLUB VALENTINE lol.
    Just remember your enclosure is everything to a sub. A Crapy woofer in a great box sounds like a great woofer. A Great woofer in a Crapy box sounds like a crapy woofer. Just be sure to take your time.
  • Jim Shearer
    Jim Shearer Posts: 369
    Since no one else has mentioned it: there is a whole section devoted to building subs on DIYaudio.com under 'Loudspeakers'.
    Cheers, Jim
    A day without music is like a day without food.
  • chrism
    chrism Posts: 8
    Valentine thanks for mentioning the importance of the enclosure. As you said .... a quality woofer in a poorly enclosed box is basically a waste of a good woofer. I know from experience ......
  • jinjuku
    To build enclosures properly you have to have a few solid tools. For me it's a router and table saw.
    I also use a dado blade to do a proper tongue and groove for window braces that interlock with the rest of the cabinet. Currently running two 12" subs in a 3.5 cubic foot enclosure that is nothing but dado + brace and wood glue. Not a single screw or nail.
  • schutz2106
    schutz2106 Posts: 115
    edited October 2010
    Thanks for the info. Probably try to start doing something when the snow flys.... WHICH will be soon...........................................
    Klipsch RF7-II
    Klipsch RC64-II
    Klipsch RC62-II
    Onkyo TX-SR805
    Dish 722 dvr
  • xj4094dg
    xj4094dg Posts: 1,158
    edited October 2010
    "The good thing about science is that it's true whether or not you believe in it." Neil deGrasse Tyson.
  • zarrdoss
    zarrdoss Posts: 2,562
    edited October 2010
    I built this for under $400 and it sounds fantastic. sealed is much easier than ported, there are a bunch of free programs you can use on line to find correct plans for ported.
    http://www.polkaudio.com/forums/showthread.php?t=101110
  • schutz2106
    edited October 2010
    kinda looking at axiom 600 size sub diy. This would fit in my room and look great.
    Klipsch RF7-II
    Klipsch RC64-II
    Klipsch RC62-II
    Onkyo TX-SR805
    Dish 722 dvr
  • edoggrc51
    edited October 2010
    zarrdoss wrote: »
    Nice job!! :)
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
  • ben62670
    ben62670 Posts: 15,969
    edited October 2010
    Ben
  • edoggrc51
    edited October 2010
    ben62670 wrote: »
    Sweet subs! How ya like them? What kind of box(s) do you have them in?
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
  • ben62670
    edited October 2010
    Way more powerful than any sub I have heard. I first did a sonosub then I did a pair in sealed enclosers. If you go sealed you will need to EQ it a bit.
    Ben
    Ben
  • edoggrc51
    edited October 2010
    Yeah EQ makes a big difference. I'm running an LMS ultra in a sealed 24" cube. Getting the SMS-1 dialed in made a HUGE difference. :)
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
