How do you adjust Onkyo 800 "late night settings"?
brentski
brentski Posts: 96
edited June 2003 in Electronics
On the Onkyo 800 rcvr., I know how to turn the 'late night' setting on by going through the sub-menu and I've found out how to turn it off by the simply hitting the 'audio select' button on the remote.
I'm just not sure how to go about turning the 'late night' setting on again the next time I'd like to use it without having to go through the whole sub-menu each time?
There's got to be an easier/simpler way to go about this each time I want to use it.
Any help is greatly appreciated
Center; CS-400i
Main's; RT-55's
Side Surround's-RT-35's
Rear center;CS-300
Sub; SVS PB12-NSD
Post edited by brentski on
  • faster100
    faster100 Posts: 6,124
    edited June 2003
    My integra remote has a late night button on the bottom left corner i think, Onkyo 800 should be comparable, does your remote have a button somewhere that you didn't see?
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • brentski
    brentski Posts: 96
    edited June 2003
    Nope,no such button on my remote.
    Once I set it going to the 'night-mode' through the on screen sub menus, I can revert back to normal by pressing the 'audio select' button' on the remote, however, I seem to have to go back through the sub menu to reset the 'nite-time' modes when I want to use it again.
    There must be an easier way but I can't seem to figure it out
    again,any help would be appreciated.
    Thanks,brentski
    Center; CS-400i
    Main's; RT-55's
    Rear center;CS-300
    Sub; SVS PB12-NSD
