Sprint Overdrive 4G Mobile Hotspot Question
toucanet
I'm not sure if this is the right forum for this post. If not, a mea culpa is in order.
I'm currently looking for portable, on-the-go internet access and was wondering if anyone has used/is using the Sprint Overdrive.
If so, what are your comments about it? If not, what are you using and your comments about it?
toucanet
toucanet
Post edited by toucanet on
i have used the over drive and it is great. It will allow up to 5 users at the same time. You will only get the 4g service in areas that have 4g. Other than that it is great. VEry easy to setup and use.
Let me know if you have any questions. I worked at sprint for years and am very familiar with the service.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Thanks for responding packetjones.
Can this device be hard-wired (via USB) to a desktop computer while still providing the wireless services? -
I know that you can connect it via the usb but I am not sure if it can provide a connection via usb and still broadcast the wifi connection.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
