Surround Sound on SACD
acmf74
acmf74 Posts: 937
edited September 2010 in Electronics
If I wanted to listen to a SACD in 5.1 do I set my AVR to 5ch stero or on another mode? I know I know NOOB question.
Post edited by acmf74 on
  • vc69
    vc69 Posts: 2,500
    You will have to either:
    A) Use your analog Multi-Ch inputs
    or
    B) have a receiver capable of decoding DSD bitstream, choosing the 5.1 layer of the disc will switch the receiver into the proper mode I believe.
    or
    C) send multi-ch PCM to your pre/pro and choose "direct" or "multi-ch PCM" or whatever.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
  • acmf74
    acmf74 Posts: 937
    I have it connected by analog cables and the screen reads DSD (not sure what that means).
  • vc69
    vc69 Posts: 2,500
    So you have 6 analog IC's from your player to your receiver?
    If so, choose the multi-ch analog input on your receiver and make sure you have selected the 5.1 layer of your SACD with the player. Voila'!
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
