Harry Brown and my OPPO BDP
NeilGabriel
It appears that this movie put my OPPO into a prolonged loading after which the player said it did not recognize the disc. A couple emails to and from OPPO resulted in me sending the unit in for repair.
After the problem started, it would not load any dvd, br or not, and not even cd's. OPPO was pretty sure it was the disc that caused the problem....anyone else with an issue like this?
Post edited by NeilGabriel on
Did they request the disc as well?-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I got an Oppo BDP-83SE; it played "Harry Brown" BD fine. You might want to try to run the latest firmware to see if the update actually clears the problem.Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000
