TC80i
grkstl
grkstl Posts: 3
edited September 2010 in Speakers
I just baught 4 of these to put in the ceiling of my room. The room size is 16'x22'. My question is do I need to insulate the ceiling cavity behind the speaker?
Post edited by grkstl on
  • mufsoman
    mufsoman Posts: 640
    At one time I had a pair of these for the rears in a 7.1 set up. I bought a package of fiberglass insulation sheets that were couple inches thick x 2' x 4' at the local home repair store and made a five sided box out of it. I install this in the ceiling so it covered the speaker once installed. Because its soft fiberglass, it was easy to push through the hole in the ceiling and position. I think you'll need something to keep sound from reverberating through the area above the ceiling and to minimize the sound carry to other parts of the house.
    Sony 83A80L TV and Roku Ultra
    Denon 3800
    Parasound HCA-2205A
    SVS Prime Pinnacle towers, Ultra center channel and Prime bookshelfs (side surrounds)
    Atmos: Polk OWM3 x 4
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
    Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
