Amp to power SR124?
![nstillmatic](https://w3.vanillicon.com/31eb2aad2ee62fa61e09102f59c19275_100.png)
nstillmatic
Will I be able to power a SR124 with a JL Audio 500/1? From what I've read this amp is underrated and actually pushes 750W or so. Is that enough?
Also, would it be better to go with a single SR124 or two MM1240s instead?
Post edited by nstillmatic on
Since sr124 is rated 700W rms then your 750W will be perfect. That is IF your 500W amp actually does push 750W as u state it does.
as for 1 sr or 2 mms - well, that depends on way to many things for us to be able to tell you which one is right for you.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
