To amp or not?
ratster
ratster Posts: 324
edited September 2010 in 2 Channel Audio
I got an itch to try out an amp on my lil outfit.Due to limited space I'm kinda leaning towards a mk545ii or something similar.Will I benefit from this with my set up or am I just better off holding out for a 5500 or something else along those lines?:confused:
Thanks,
Rhett
Main
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Clear Day dbl.shotgun
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Clear day dbl shotgun
Post edited by ratster on
  • steveinaz
    steveinaz Posts: 19,546
    Given your setup, I'd roll with what you have until you can get the amp you truly want.
  • kawizx9r
    kawizx9r Posts: 5,150
    I'd do a search on those powering their monitors with an external amp that had them hooked up to an AVR before-hand and read up on their comments.
    I've always heard a significant difference when hooking up a pair of speakers to a very capable and high-current amp, but the Monitor line of speakers are very efficient and most owners would say an AVR will suffice.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • organ
    organ Posts: 4,969
    Do you have a friend you can borrow an amp from? That way ou can try it out without spending any $. Better to get the one you really want like Steve suggested.
  • ratster
    ratster Posts: 324
    Thanks for the replys.
    I could probably make a 5500 or 5800 fit if I removed a shelf from my so called rack.This would let me put the amp on the bottom and set my receiver on top of it and everything should fit.Is this acceptable or not? I was kinda worried about things gettin to warm.
    Main
    Parasound P5
    Parasound A21
    CA music streamer
    marantz 6005
    Morrow Xlr
    1.7 Maggies
    Bedroom
    adcom Gfp750
    Adcom 555
    Rotel 1072
    CA tuner
    LsiM703
  • organ
    organ Posts: 4,969
    Don't do it. Even if the heat doesn't kill one of the unit, the amount of dust that will accumulate inside your receiver will be a lot.
    If you don't have room on your rack, place it on the floor. Make some sort of amp stand like you see in hifi shows. Make sure the bottom vents don't get blocked.
