carver m1.5t - common ground
Bnewsom
Does anyone know if the carver m1.5t is common ground. Tried to search the forum, but no luck. Tried to google it and still search through it. Thought I would simply ask the experts. Thanks.
Post edited by Bnewsom on
yes it is
I have 3 of them. I have used one of them with the A-1 interconnect cable on my 2.3's with no issues.My 2012 HT Room - http://www.avsforum.com/t/1416077/bsoko2-new-ht-june-2012
Thanks - for everyone that took the time too respond. Have a chance to get one for 250. I recently bought some sda 2 org. and was not all that happy with them. Some music sound amazing but some not so much. Was pushing them with a onkyo 150 per and my rta15tl on the same amp just sounded better. Hoping the extra power will wake them up. If this do not help, will try a crossover upgrade, all ready had to replace the polyswitches. Thanks again.
be sure you check it for humming at 0 volume, ever so slight buzz through tweeters where you have to stick your head up to them to hear the buzz is OK. If its loud though it might have to be re-built.
Will do, Bob carver opened a repair shop, if any problems I will ship it off to them. I'm located in Oklahoma, so repair shops is far and in between. Thanks for the advice. -
Thats what I did with mine and even had Mr Carver sign it, but it was $175 flat fee then.
