Need Some Box Buildin Demisions
ChevyMan4x4
ChevyMan4x4 Posts: 52
edited June 2003 in Car Audio & Electronics
Ok... I am not real good at crunchin the numbers.... I am trying to build a box for 6 10'' MTX Thunder 6000's I want it sealed and need .75 cubic feet for each chamber..... I am putting it in a blazer so size is not a big issue got plenty of room... if you can help me with the dimensions you would be a great help....
looking for this design...
| O O O |
| O O O |
Sir Daniel X. Boom - the GNX slayer
Post edited by ChevyMan4x4 on
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited June 2003
    how deep are the subs?
    -Cody
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited June 2003
    dont tell me you bought the goddamn 12 ohm verions ???
    i was gonna do that in my truck -- then i got the 4 dx 12's -- i prolly wudda liked the 6000's better... lol.
    good luck with that...
    what kind abox u want man ? just square ? how tall ? up to the ceiling ?
    and do u wat the subs front firing , rear firing , downfiring , up firing ??
    The Artist formerly known as PoweredByDodge
