Speakers or Electronics
ALWALLER
ALWALLER Posts: 40
edited September 2010 in Electronics
Hi all
Put in Prince of Persia yesterday, and the first theater preview
cost me some concern.
It looks like a up-dated Tron movie. I had the volume @ -17, my room
is 15' x 20'. The audio started out good but as the preview progressed
the distortion increased to a unacceptable level. My normal listening
level is -17. Should my speakers distort at this volume ?
Is the preview recording hot ? Never had a problem with any other
Blur-ray before. My equipment is listed below. Is it the speakers ?
My electronics ? The disc ? or a combination of the above?
AW
Equipment
Panasonic TC-P54S2 Plasma
Scientific Atlanta DVR
ONKYO TX-SR705 AVR Pre/Pro
Outlaw 7125 7 CH Power Amplifier
Toshiba A2 HD-DVd
Panasonic BD-30
Harmony 550 remote control
LSi9 ( Mains )
LSiC ( Center )
PSB Ambient 2 Dipoles
SVS 20-39 PCI Subwoofer
Post edited by ALWALLER on
  • jayman_1975
    jayman_1975 Posts: 672
    It sounds like it's your gear. Start over from scratch is my advice. lol kidding. Did you try popping a different dvd in right away to see if it still sounded like garbage?
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • ALWALLER
    ALWALLER Posts: 40
    Jayman_1975
    I wish I could afford all new gear, I would not be asking
    questions now!! It happen only on that preview.
    It sounded great at the beginning ( DD ).
    Equipment
    Toshiba A2 HD-DVd
    Panasonic BD-30
    LSi9 ( Mains )
    LSiC ( Center )
  • packetjones
    packetjones Posts: 1,059
    Is it only that preview that had issues? Did the movie sound fine? Are there any other times that the system was distorted?
    It could just be that one preview was poor quality. Just a thought.
    Front - RTiA5's
    Rear - RTiA3's
    Center - CSiA4
    Sub - PSW110
  • zingo
    zingo Posts: 11,258
    I would also test out other material and discs. Your equipment looks fine, and I can't see unacceptable distortion coming from LSis driven by an Outlaw.
  • cstmar01
    cstmar01 Posts: 4,424
    agree with the above. test other discs, other previews, ect ect. If it continues its probably a problem with A the player or B the amp or pre amp with the signal. Also is it every speaker that has the distortion or only like one ect. Do a process of elimation, if its one speaker, could be a bad connection ect with that speaker. If its only doing this on the one preview, on the one disc, its probably the disc and a poor recording on it.
  • ALWALLER
    ALWALLER Posts: 40
    Thanks you all for your replies
    The sound on the balance of the blu-ray was fine.
    I tested two others blu-ray and no problem.
    I think Packetjones & cstmar01 have limited the problem
    to a poorly recorded preview. Should have thought this thru
    myself. Thanks again for your help.
    Equipment
    Toshiba A2 HD-DVd
    Panasonic BD-30
    LSi9 ( Mains )
    LSiC ( Center )
