Thoughts on this setup........
![FHT](https://w1.vanillicon.com/1a626b881e9884b546586a9e4cca0ad4_100.png)
FHT
4 x Polk Audio MM571
Rockford Fosgate T400-4
Kenwood KDC-BT945U
Thoughts?
Kenwood KDC-BT945U
Thoughts?
Post edited by FHT on
sounds like a Ford product if it's got four 5x7'sTruck system so far...
2007 Dodge Ram 1500 quad cab Hemi
Kenwood KDC-X492 HU
MM651 coaxials in doors
Family Room:
Panasonic TC-P50G25 50" Plasma
Panasonic DMP-BD655K BDP
XBOX 360 250GB
Harman/Kardon HK3480(on loan)
Monitor 70 Series II -
boom boom boom
Kenwood KDC-BT945U
Thoughts?
How about 2 x MM6501 upfront, they will fit the 5x7 opening with a spacer.
Nothing at the rear.
You can get other decent amps for the price of the RF, which will give you more watts.
Btw wondering if your original post was made from your phone...it reads like an sms. Yeah, the least you could have done was mention the car you're putting all this into.
A 10-12" sub in a sealed box in your boot. 10" would be plenty if you drive a hatch.
The hu has some dsp which is good. If you're a set it once and let it play kind of person then yes, this hu is fine.
Btw, your post read like an sms. You could have mentioned the vehicle at least -
I would stay away from rf amps unless you are running amps with them. Not the bes for speaker amps. Look at alpine, polk, and cdt.
www.woofersetc.comHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900
