rear surround recommendations
What inexpensive Polk speakers would you recommend as rears for a 5.1 system with a CSi A4 center, RTi A1's left and right and an old Yamaha sub? Thanks.
Post edited by gamafn on
I'd try and pick up another set of used A1's, should be pretty cheap. In my experience, using the same center or surrounds as your fronts provides better imaging. Plus you don't have to worry about timbre matching.Current System:
Paradigm Signature S2 v2
Conrad Johnson MF2500
Wyred4Sound DAC2
Audioquest Black Mamba II
For Sale:
3x Wilson Cub's
Conrad Johnson MF2500 -
Another set of A1's would be good. You should also check out the OWM3's. They are very versatile and would work well as surrounds.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
