Tweeters buzzing
mfi
mfi Posts: 9
edited June 2003 in Speakers
I just noticed that my tweeters buzz and crackle a little. Rt600i's. Pretty new, about 6 months old. Could they both be blown?
Post edited by mfi on
  • fgr41
    fgr41 Posts: 432
    edited June 2003
    Have you been driving them hard? What kind of amp are they connected to? Are you running them as fronts? HT or audio? New out of box speakers or what?
    Front
    Polk RT800i (BI-wired)
    Rear
    Polk RT600i
    Center
    Polk CS400i (BI-wired)
    Sub
    SVS 25-31PCi (22Hz tuning port)... it's SubHuman
    Receiver
    YAMAHA RX-V1400
    TV
    Mitsubishi WT-46807 HDTV
    HD receiver
    T i V o HR10-250
  • mfi
    mfi Posts: 9
    edited June 2003
    I don't run them hard, small room. They are in a 2 channel setup. Yamaha M-85 amp. I replaced them with my old speakers , no buzz, so I know its not the amp. They were new, but could have been floor models. You never know. The wiz went out of business. I'm calling customer service, if all I have to do is yank them and send them back, no prob. I like my old speakers better anyway, lots more bass. 21 years old and they still crank.
  • fgr41
    fgr41 Posts: 432
    edited June 2003
    They should not buzz or crackle. I would look into geting them repaired as they will still be under warrenty and it sounds as if it IS the speaker. Does it do this with all sources, radio, cd etc...?
    I understand you liking the old speakers because of the base the 600's dont pack the low end punch but when paired with a sub they can do amazing things.
    Good luck at what ever you choos but please let me know, I'm currious to see what happens.
    Front
    Rear
    Polk RT600i
    Center
    Sub
    Receiver
    YAMAHA RX-V1400
    TV
    HD receiver
    T i V o HR10-250
  • mfi
    mfi Posts: 9
    edited June 2003
    If I get or build a sub I might put them back. I'll post the outcome.
