adcom 555 question
sda2mike
sda2mike Posts: 3,131
edited September 2010 in DIY, Mods & Tweaks
i had a channel go out on my adcom 555...checking for dc at the spkr outs..the left channel is stable..the right (bad) has a reading that climbs..while idle you can hear, mostly thru the sda channel: crackling every so often. what gives???
on a side note: when this happened w the adcom, i pulled my marantz 2270 out of the closet...i gotta tell you: it sounds really good! top to bottom..shows just how good the TL upgrade on my 2b's is..i might keep the marantz on duty for awhile...looks nice too
