Carver Tfm-42
Elinvader
Hi, going to pull the plug on a tfm-42 , but the owner tells me that i need to replace some capacitors on the amp due to its age...He was telling me about a place in Washignton call Ritas that rebuild Carver to its factory condition and actually could get Bob Carver to sign the amps....Done research but cannot find the website..Just want to know if some polkies here has heard of this place or has send their amps to fix in Ritas ? Just want to be sure before i pull the plug on this amp...The carver is for a pair of Sda 2Bs....Any input will help ...Thanks
Post edited by Elinvader on
They exist allright and Mr. Bob Carver probably would sign anything you want on it.
They would go over everything and bring it to like new specification for their flat rate of 350.00 I think.
A 1 yr. guarantee comes with the overhaul to.
The flat rate is firm by the way....
I sent an amp to them for repair a yr. ago.Most people just listen to music and watch movies. I EXPERIENCE them.
I would also check out Roland at www.carveraudiorepair.com
I have been REALLY happy with his service and he does get deeper into the product than Rita, Both are good but for the money i would talk to Roland also. -
Another vote for ROlland, he will go over top to bottom and do the worked required.
I have used him on a TFM-45 and 55.Speakers: SDA-1C (most all the goodies)
Rolland would also be closer to ship too than WA if you're in Florida.. I think he's in Illinois or somewhere close IIRC
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
His address on the site is in Oregon:
Hi-Tech Audio Ltd.
Address: 2125 SW 19th St.
Gresham, Oregon 97080
If he's in IL that would rock since I might need some work done to my Carver AV-705x and might be able to drive it out there...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
My Carver TFM-45 was serviced by Rita's and signed by Bob. Sounds superb.SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
Even Bob himslf goes with Rita.:)The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
lol... oregon.. i was way off.. for some reason i thought he was in the Mid-East area hahah
Pre: Dodd ELP
DAC: W4S-Dac2
Jason
I thought when I was looking around I found a guy in Ohio or NY, but I didnt bookmark it. Personally I would go with Rita or the other mentioned person."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
EndersShadow wrote: »I thought when I was looking around I found a guy in Ohio or NY, but I didnt bookmark it. Personally I would go with Rita or the other mentioned person.
Why ?
Ever used Rolland ?
My TFM-45 was repaired by Rita a year before I bought it. Owner had receipt.
Went to Rolland 8 months later for peace of mind and I am glad I did.Speakers: SDA-1C (most all the goodies)
thanks guys for the replies...Just what i was looking for...:)
My carver 1.5 was serviced by Rita's- that was one of the reasons I bought it. Carver audio repair is the only Licensed repair center designated by Sunfire. They handle all Carver stuff.
There's one more place- the guy who makes the "Mark ll" series of amp improvements.
Maybe someone here could tell me what they think of this guy. I'll see if I can't get the link
munk -
