DIY sub gain setting
fattmann
fattmann Posts: 58
edited September 2010 in DIY, Mods & Tweaks
Getting ready to build a subwoofer for my brother's workplace and had a question about setting the gain on the plate amp. It's a fairly decent sized room, bout 33x17'. Purchased the Dayton Audio 500w plate amp and will prolly go w the HF series 15" Dayton sub.
I got the amp the other day in the mail and have been playing with it on my sub, a 12" Kicker solobaric car sub. Ultimately it will be hooked up to a Yamaha 663. My main concern was setting thus gain to prevent clipping. The amp has a green status light that shifts towards red in the event of clipping. What method should he use to set AVR sub out levels and plate amp gain?
Components in The Rack:
Yamaha RX-V765 7.1 AVR
Sony TA-N511 (from 1065 to sub)
Xbox One
MA PD-915R Power Strip
Monster HTS-1650
Speakers:
L/R- Polk TSI-500 Cherry, 12awg in place of jumpers
C- Polk CS20 Cherry
SRs- Polk TSI-100 Cherry
Sub- Kicker S12L5, vented box
Display:
Sony VPH-1252Q
75" 16:9 DIY BO Cloth Screen
Not running:
Crown Straight Line Two
Crown Power Line Four
Pioneer PD-F908
Fender BXR Dual Bass 400
Pioneer BDP-51
Post edited by fattmann on
  • ShinAce
    ShinAce Posts: 1,194
    The ghetto way to do it is to play the loudest song you have(something like 'confusion' from the Blade soundtrack) at your main speakers max level. Now bring up the gain on the sub until it begins to clip. Then back off a tiny bit so that it doesn't clip at all. Usually, if you get it to clip and turn it down to exactly where it stops, it'll start clipping again as the amp warms up.
    A better way is to just set it by ear and watch the clip light on a few test tunes or test movies.
  • fattmann
    fattmann Posts: 58
    Tried essentially that "ghetto" way, but ran into it clipping before it was even moderate SPL. The sub out on my receiver has a huge range, so essentially i'm dealing with 3 "volumes:" AVR volume, Subwoofer out level and Amp gain.
    Perhaps i just didn't spend enough time playing with it..
    And wow, going from a ~200w amp that i usually have my sub on to this ~500w plate amp really revealed some air leaks in my box... lol
    Xbox One
    Monster HTS-1650
    Speakers:
    C- Polk CS20 Cherry
    Display:
    Sony VPH-1252Q
    Not running:
    Pioneer PD-F908
    Pioneer BDP-51
  • Storminone
    Storminone Posts: 19
    It shouldn't be clipping out at a moderate level. Gain and level on sub and AV should both be below or at half.
    The PE amps take a 4 ohm load. What's the Kicker rated at? Might be your problem if it's 2 ohm and trying to push it
    Monitor 60
    Monitor 30
    CS10
    Titanic MKIII 12
  • fattmann
    fattmann Posts: 58
    It's a dual 2ohm wired at 4.
    So what does that say about my setup that the auto-calibrate always sets my sub to like 75%? lol One of these days I'll get a proper amp for my own...
    Xbox One
    Monster HTS-1650
    Speakers:
    C- Polk CS20 Cherry
    Display:
    Sony VPH-1252Q
    Not running:
    Pioneer PD-F908
    Pioneer BDP-51
  • Storminone
    you can't use the auto on the receivers for subs It never works
    It's probably clipping out because the input signal is too high if it's at 75%
    lower the receiver's level to about 40 or 45% and then set the SPL with the sub's volume knob
    Monitor 60
    Monitor 30
    CS10
    Titanic MKIII 12
