Couple of Questions about Parasound 2250
  • PrazVT
    PrazVT Posts: 1,607
    edited September 2010
    Well, you sir, have great taste if you like Dire Straits :) I grew up listening to what my Dad listened to when he was a grad student. I still remember when I was a little kid, him playing the 'Love over Gold' record on his Dual turntable, through the Yamaha stereo receiver.
    I do enjoy long, winding, songs like the aforementioned Dire Straits / Floyd tracks. And it's even better now! I'm with you on rediscovering music - I worked from home today so I could listen to the system (yah I'm addicted now). So the music's been playing for the better part of 14 hrs today.
    A wall of warm clarity & surprisingly STRONG, tight bass. Addicting.
    I will say this about upgrading - because I was kind of buying things and learning from reading posts on here, I made a couple of mistakes: Onkyo M-282 amp -> not nearly enough power, Polk CS20 -> should have gotten the CSI A4/A6.
    This is probably it for a while, until the bank account is sufficiently replenished :) I do want to get the correct center speaker eventually ...
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • HB27
    HB27 Posts: 1,518
    Congrats on the amp. It's great when you upgrade and are happy with the results.
  • dekuda
    dekuda Posts: 756
    Man, if you get a chance get the A6 center or if budget is tight look for a used CSI 5 center. It is a very nice center channel though rather big.You can get a used one for a pertty good price and it will match with your RTI a7's. Keep a lookout for one because you will not believe the front soundstage you will get and the seemless transition between the fronts and center. It will be a wall of sound that will fill your room even more:D
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • PrazVT
    PrazVT Posts: 1,607
    Patience is not one of my bigger virtues so don't tempt me :)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • sm88
    sm88 Posts: 353
    I just went from an HCA-1205A to a pricier, more powerful Anthem MCA20 and I can't say there is a substantial difference, a testament to the Parasound design. Floyd's a good choice, but do throw some King Crimson at your setup!
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
