SDA Names
Vette C6.r
Vette C6.r Posts: 1,560
edited September 2010 in Vintage Speakers
Is there any significance or relative history to the naming of the SDA SRS models?
1.2
2.3
3.1
Do they have any meaning or are they just random model numbers???
I have too often wondered this.
Post edited by Vette C6.r on
  • inspiredsports
    inspiredsports Posts: 5,502
    1, 2, 3 pecking order by model (left of the decimal point) and .1, .2 version number (right of the decimal point).
    A lower model number was designed to be a bigger/better speaker, and a higher version number an improvment.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • Joe08867
    Joe08867 Posts: 3,919
  • Vette C6.r
    I get the pecking order. Just wasn't sure after the decimal point.
    Not sure I follow you Sport. After the deciaml point is the version number ??
  • Joe08867
    Kind of like windows in the early days. 3.0 then 3.1. The higher the number after the Decimal the better the version.
    heiney9 Posts: 25,497
    Joe08867 wrote: »
    Yeah, I don't think so as there never was an SDA 3 or 3.0 or 1.0 or 1.1 or 2.0 or 2.1 or 2.2
    I don't see any correlation between the model numbers and any sort of pecking order when it comes to the decimal point.
    Here's the model number pecking order, now maybe a numerologist can make sense of it, but I can't
    SDA 1
    SDA 2
    SDA 1A
    SDA 2A
    SDA 1B
    SDA SRS 2
    SDA 2B
    SDA CRS and CRS+ (Compact Reference System)
    SDA 1C
    SDA SRS
    SDA SRS 1.2 and 1.2TL
    SDA SRS 2.3 and 2.3 TL
    SDA SRS 3.1TL no non-TL model
    So you tell me how that is a linear pecking order that makes any sort of sense to someone unfamiliar with SDA's?
    Toolfan66 Posts: 18,181
    It's more like a rev change to me..
    But then why not 1.1 or 2.1 instead of 1.2 and 2.3? I'm sure there is an internal reason. It's just not that apparent to the consumer. Just like the new LSi series has a different model designation and it's an internal thing as to why and what the letters mean.
  • Vette C6.r
    heiney9 wrote: »
    Me neither. I guess we'll never know.
    Thanks for the input guys.
  • gdb
    gdb Posts: 6,012
    If six turn out to be nine.......I don't mind
    The only thing that matters is they KICK ****...;)
  • inspiredsports
    All I would ask is that you you go to your Compendium or DarqueKnights thread at . . .
    http://www.polkaudio.com/forums/showthread.php?t=55888
    and spend a while opening and studying the linked Adobe Acrobat .pdf files.
    Then tell me, for instance, how drawing Number P0161001 corresponds to P0161002 and what P0162003 or P0163001 mean?
    Oh, Really . . . ? Imagine that!
    Now, can somebody edit out all of the **** between my answer in post # 2 and this post?
    P.S. Note the OP asked about 1.2, 2.3, 3.1
    NAD SS rigs w/mods
    GIK panels
